SSLV1.1 builds & fairy tales - Page 220 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th April 2013, 04:36 PM   #2191
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Technically not bellow the ripple current capability you need so you may try but 10.000uF seems more natural for >1A.
Old 26th April 2013, 02:19 PM   #2192
I want to use the SSLV1.1 for 50v 900ma regulation. Anyone can tell me whether the SSLV1.1 capable to the task??
Thanks!
Old 26th April 2013, 02:28 PM   #2193
Salas's Avatar
Q102 has 50V max spec. The voltage across it is VinDC-3xLedVf. That is the input limit. It will be on the edge even if careful and with only 5V Vin-Vout. Not recommended, risky for mains variations or input transient.
Old 26th April 2013, 02:52 PM   #2194
Abraxas336's Avatar
Regarding CX01,CX02 and CX03,CX04 - I just realized that appendix 4 of the document only talks about CX03/CX04 and the fact that RX07 will have to be bridged if an Ecap is used.
What about CX01,CX02? According to the Bom its either 220uF Ecap or film - does the same principle as described in appendix 4 apply (do I have to remove RX04 if I use 220uF Ecap in CX01)?
Sven
Gruenschnabel
Old 26th April 2013, 03:01 PM   #2195
Salas's Avatar
No, RX04 remains. Its just a base stopper in series.
Old 26th April 2013, 03:04 PM   #2196
Salas's Avatar
Originally Posted by Abraxas336 View Post
So I've been trying to figure out what to put on the board - could somebody confirm?
DC in: 49VDC (35VAC)
V Out: 36VDC
Load Consumption: 80mA (line level preamplifier)
Constant current (Q101): 200mA (lets have a little headroom )
R101: 20R
R103: 7kR
R105: 2kR Trimmer
R102,106: 270R (Mosfet)
D102-4: 4x green, 2V
D105,106: 2x red, 1,9v
D101: Jumper
C102,104: 10uF film
I don't know if the R/film choice is the right one for my load - its Chokys Pumpkin preamplifier, schematics here.
Many Thanks
Sven
It should basically work as you configured it. R101 20R sounds high for 200mA though. Use the calculator from post 1.
Old 26th April 2013, 03:28 PM   #2197
Abraxas336's Avatar
Thanks Salas. I'm using a 220uF Ecap in CX01 now to reduce the amount of leftovers laying around from previous projects.
I did, thats what it told me to do.
Best Regards
Sven
Gruenschnabel
Old 26th April 2013, 03:38 PM   #2198
Salas's Avatar
You put it to work and the voltage drop across R101 20R confirms 200mA by Ohm's law I=V/R?
Old 26th April 2013, 03:39 PM   #2199
Originally Posted by Supersurfer View Post
Here are some pictures of the heat sinks
what brand and value are films on that picture
Old 26th April 2013, 04:00 PM   #2200
They are Angela (rebranded Solen) MKP caps for tube amp usage; 4,7uF/600VDC. They are bit big but I have al lot of them lying around.
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1464 20th July 2014 01:54 PM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
