SSLV1.1 builds & fairy tales - Page 210 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 1st January 2013, 07:48 PM   #2091
le´flu is offline le´flu  Germany
Hi everybody,
Salas recommended at the njfet thread a SSLV1.1 for the FoldedSimplistic that
should draw 200mA (CCS) at 35Vout.
The BiB-cookbook just has schematic without parts and values.
Question: is there somewhere a BOM and schematic for a BiB/SSLV1.1 that
suits the FoldedSimplistic?
Sorry for being lazy
Greetings ulf
Old 1st January 2013, 08:50 PM   #2092
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
No, it has much discussion and examples and there is an Excel calculator on first post also. Anyway, use example (e) with one led only, jumper the second led position. That will put it in the adequate voltage range to set 35V with the trimmer. Use 15R 3W to 5W for R101, R301 and 4x 1.9V leds for D102 etc. it will set circa 200mA CCS. All other non application specific parts have standard values in the guide's bom.
Old 1st January 2013, 09:53 PM   #2093
Hi Salas,
thanks ... just played with the exel sheet around. At operating point V out
is 35V. CCS (Q101) is 200mA But how high is load consumption?
In the BiB sheet you recommend DC in to be about 10Volts higher than V out
- right?
Greetings ulf
Old 1st January 2013, 11:19 PM   #2094
Salas's Avatar
Yes, 10V drop over the 1.1 reg is more than fine. Each folded simplistic channel (1x2SK369 input stage, pdf circuit) will consume ~30mA. The 170mA spare will allow for good B+ output impedance when burning on the Mosfets. In case its too hot for your arrangement and sinks, you can use 130mA CCS. It may lose a bit of subjective quality VS 200mA or 300mA, but still very nice.
Old 1st January 2013, 11:29 PM   #2095
okay, sounds good. Will go and select some leds and sk170 tomorrow.
As i understand i have to use ´lytic in position C301. Which type do you
prefer? low ESR or better not? Pana FC, FM? Btw. what are your favorite
type of rect. diodes?
Thanks ulf
Old 1st January 2013, 11:38 PM   #2096
Salas's Avatar
Pana FR,FM,FC or Nichicon Muse 220uF/50V will do. Pick your favorite. MUR120 or SBYV27-100 diodes are nice too. The big filter lytic on the reg better be select quality too. 4700uF/63V is fine.
Old 1st January 2013, 11:39 PM   #2097
Salas's Avatar
P.S. 2SK117GR, not 2SK170BL for the reg. There have been funnies when some attempted.
Old 3rd January 2013, 06:29 AM   #2098
Good morning,
salas, could you please post the schematic of the plus-regulator out
of the BiB-sheet? I can´t extract it out of the pdf and would like to
have it for writing values of parts on it.
Greetings Ulf
Old 3rd January 2013, 06:58 AM   #2099
qusp is offline qusp  Australia
qusp's Avatar
cant you do screen captures of the pdf?
Old 3rd January 2013, 07:05 AM   #2100
Salas's Avatar
Straight from my LTSPICE schematics bank set at 35V you want.
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1627 14th January 2017 04:43 PM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 10:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 10:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 06:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 09:23 PM
Copyright ©1999-2017 diyAudio
