SSLV1.1 builds & fairy tales
Old 30th December 2012, 09:13 PM   #2081
vgeorge is online now vgeorge  Greece
vgeorge's Avatar
Originally Posted by RCruz View Post
Hi Salas
Starting to build the SSLV1.1 but my boards have 4 leds for biasing the ccs mosfet. The build guide only has reference to three.
Why the fourth led ?
Ricardo,
if you want to use higher current, you cant use a higher value resistor with 4 leds. That' s why they use 4 leds in the last pcb. You can always short the forth led and use 3.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 30th December 2012, 09:24 PM   #2082
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi vgeorge, I usually use a lower value resistor to set higher current.
Using four diodes with a higher value resistor is new to me... but I found it:
(3xVf LED)-VgsQ101=VdR101. ICCS=VdR101/R101. Example: 3x2.1V LED and a Q101(201,301) MOSFET
with 4.3V Vgs will create 2V drop across a 10 Ohm R101. ICCS=2V/10R=200mA.
So 4 leds will create a 4V drop over R101... if I use R101=15 I get ICCS = 267mA
Perfect
RC
Old 31st December 2012, 05:34 AM   #2083
vgeorge's Avatar
4 leds come handy if you want more than 500 mA.
Your calculations seem correct and the end result will depend on actual Vgs and leds Vref values.
If you compare with your 1.2 builds, I will be very interested for your opinion.
Old 31st December 2012, 06:01 AM   #2084
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Hi Salas
Old 31st December 2012, 06:17 AM   #2085
nhinstruments
RCruz's Avatar
In reality the BiB spreadsheet allready has all the calculations needed... must be more carefull in the future
RC
Old 31st December 2012, 06:31 AM   #2086
Salas's Avatar
You should do the VGS curves of 9530 by eye because the curve embedded in the calc is for 9610. They are Interchangeable on board, but 9610 is the fastest one for open treble while 9530 being no real dork but not as good is the tougher one for special purposes like delivering 1A and beyond to things like WiFi music centre appliances.
Old 31st December 2012, 06:33 AM   #2087
Salas's Avatar
Read http://www.diyaudio.com/forums/power...ml#post3274708 for an IRF9530 example and its curves annotated for calculations. By using another ICCS red horizontal line level you can find your own points for 3 or 4 Leds populated.
Old 31st December 2012, 06:52 AM   #2088
nhinstruments
RCruz's Avatar
Thank you Salas
From what I read, IRF9610 is faster and if I do not need high currents, maybe the best choice would be to use it in both positions... right ?
RC
Old 31st December 2012, 07:22 AM   #2089
Salas's Avatar
Not both positions. CCS. It lacks enough transconductance for shunt position. You wrote at a point about using 9530 for CCS I saw.
Old 1st January 2013, 06:48 PM   #2090
le´flu is offline le´flu  Germany
Hi everybody,
Salas recommended at the njfet thread a SSLV1.1 for the FoldedSimplistic that
should draw 200mA (CCS) at 35Vout.
The BiB-cookbook just has schematic without parts and values.
Question: is there somewhere a BOM and schematic for a BiB/SSLV1.1 that
suits the FoldedSimplistic?
Sorry for being lazy
Greetings ulf
SSLV1.1 builds & fairy talesHide this!Advertise here!
Legis' Horny Tales Legis Multi-Way 176 11th September 2017 12:21 PM
Any successful/unsuccessful tales of loading a large Coax in a front horn? POOH Multi-Way 35 22nd November 2015 08:58 PM
Fs: Salas SSLV1.1 BIB janos_904 Swap Meet 13 27th May 2015 08:36 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
