SSLV1.1 builds & fairy tales
Old 18th December 2012, 10:21 PM   #2051
Billc is offline Billc
Hi Salas,
I tried varying the gate stoppers but still have oscillations and varying voltage. Is there any problem using 2 positive regulators provided I used separate transformers, diodes, and caps with the only connection being at the load?
I have changed most of the components on the negative regulator but still have the same problem and just cannot seem to get it to work at high shunt current draws.
Thank you for all your advice.
Bill
Old 18th December 2012, 10:33 PM   #2052
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
No there is no problem using 2 positives, see the pic, but there should be no such persistent problem in a negative too. Has been used a lot in +/- configurations by now. Don't know how much they pushed spare current though. So it makes me wonder. What make are the IRF610s?
Old 19th December 2012, 12:50 AM   #2053
I have 3 other salas shunt supplies built and all are working fine in a +/- configuration.
They are all dumping around 100mA through the shunt.
All my mosfets are International Rectifier brand.
The diagram shown is how I plan to configure the supply except I have separate transformers for each regulator.
Thanks.
Bill
Old 19th December 2012, 05:10 PM   #2054
samoloko is offline samoloko  Bulgaria
Originally Posted by RCruz View Post
+1 for sonicaps
thank you for Input
how would you compare Sonicaps to Obbligato Gold In respect to BIB
I am Interested also what Merlin does think about Sonicap v Auricap v Obbligato Gold
Old 19th December 2012, 06:07 PM   #2055
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Sonicaps teflon the best.
Old 20th December 2012, 05:50 AM   #2056
well I was talking about gen 1 caps
but you were talking about Platinums
have you tested gen 1 caps
Old 20th December 2012, 06:32 AM   #2057
tom6 is offline tom6  Australia
Is there anyway this can this be done using one transformer with a single secondary feeding both +ve boards or does each board require it's own secondary winding i.e. dual windings on the transformer?
thanks
Old 20th December 2012, 07:49 AM   #2058
No.
How I choose a film capacitor:
Dielectric film
1st teflon
2nd MKP
Conductor type
1st foil
2nd metallized
Conductor material
1st copper
2nd aluminium
3rd tin
Waiting it helps.
Old 20th December 2012, 09:11 AM   #2059
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
thank you for Input
Excluding teflon dielectric, obbligato GOLD is my preference.... Way better than Sonicap.
Auricap is very good but always leaves itīs rather special signature.... Obbligato is more transparent.
RC
Old 20th December 2012, 09:18 AM   #2060
Obbligato uses foil
Auricap & Sonicap are metallized
As said before always better foil over metallized.
SSLV1.1 builds & fairy talesHide this!Advertise here!
Legis' Horny Tales Legis Multi-Way 176 11th September 2017 12:21 PM
Any successful/unsuccessful tales of loading a large Coax in a front horn? POOH Multi-Way 35 22nd November 2015 08:58 PM
Fs: Salas SSLV1.1 BIB janos_904 Swap Meet 13 27th May 2015 08:36 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
