SSLV1.1 builds & fairy tales
Old 28th November 2012, 06:22 PM   #1971
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi Felipe
So you recommend electrolytics for BiB Vref when powering MC head amps right ?
I also found the BiB to provide a more muscular sound that way. But somehow there seems to be less detail in the highs...
RC
Old 28th November 2012, 06:28 PM   #1972
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Yes, Ricardo.
I use BG or Pana FM with great success, if you use film the sound become with less body and lacks of bass.
Old 28th November 2012, 06:43 PM   #1973
samoloko is offline samoloko  Bulgaria
do you like Pana FM better than FC
any bypasses to electrolytic caps
Old 28th November 2012, 06:47 PM   #1974
Yes I like better FM than FC, also have bettet specs.
I don't bypass the Vref cap when using Panas FM but if you want can try with a small value.
Old 28th November 2012, 07:43 PM   #1975
nhinstruments
RCruz's Avatar
Originally Posted by merlin el mago View Post
Yes, Ricardo.
I agree
I started with the V1 (similar to the BiB) and found that EL vref gave really good body.
Then I went to V1.2 and after that I built the Optimae and understood the benefits of films on vref and output.
Finally I settled with V12R that is stable.... can not go back. Ilike the utter high freq definition.
Hint: did you ever use a Amphom fp-ca-au 630vdc for Vref ? I use those in my DCB1 with outstanding results.... heavy bass with subtle hih freq detail.
RC
Old 28th November 2012, 08:08 PM   #1976
I don't tried, but are very good caps and not expensive.
Old 28th November 2012, 08:31 PM   #1977
barrows is offline barrows
Default Yes...
Originally Posted by samoloko View Post
barrows
are you talking about white Mundorf MKP
which cap replaced - electrolytic or other MKP
I use the white Mundorf MKP for both Vref (10uF) and the output cap in the zobel (4.7uF) for the BiB regs which power my Legato (I/V stage). Mainly I choose those because they are decent film caps, which are compact enough to fit without a ton of extra lead length. For powering the digital circuits, I use 1000uF Panasonic FM for Vref. If you are also running the Legato: I found with the Salas regs it worked better replacing the 100uF electrolytic caps on the Legato board with .1uF MKP as well: getting the electrolytics away from the analog circuitry all together.
Before Merlin advised the 10uF film caps for Vref, I was using 220uF SilimicIIs, bypassed under the board with .1uF polystyrene films. The bypass helped, but going to the 10uF film cap alone was better, more transparency, more real sounding.
Old 29th November 2012, 10:57 AM   #1978
Magsy is offline Magsy  United Kingdom
For the input/smoothing cap, is the size really important? Do I really need 4700/10000uf there or is 1000-3000 enough? Only powering 5v / 500ma, it seems overkill.
Old 29th November 2012, 11:01 AM   #1979
Till 200mA 4700uF more than 200mA 10.000uF, tx till 200mA 50Va over 200mA 80VA both as per BiB manual guide.
Old 29th November 2012, 12:32 PM   #1980
R.I.P.
2mF (2000uF) is generally enough for 1A of output from the smoothing capacitance and have acceptable ripple ahead of the circuit be it a regulator or an amplifier.
On that basis 500mA will require only 1mF of smoothing capacitance. 4700uF will reduce the ripple by about 4.7times lower than is normally deemed necessary.
10mF is simply silly for 500mA of load (into the regulator) current.
regards Andrew T.
SSLV1.1 builds & fairy talesHide this!Advertise here!
Legis' Horny Tales Legis Multi-Way 176 11th September 2017 12:21 PM
Any successful/unsuccessful tales of loading a large Coax in a front horn? POOH Multi-Way 35 22nd November 2015 08:58 PM
Fs: Salas SSLV1.1 BIB janos_904 Swap Meet 13 27th May 2015 08:36 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
