SSLV1.1 builds & fairy tales
Old 25th November 2012, 07:33 PM   #1931
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Does it drift on a dummy?
Old 25th November 2012, 07:36 PM   #1932
Salas's Avatar
Is the 0.1V drift stop end and is it positive or negative when it gets hotter beyond 300mA?
What your Vref array consists of? (parts in "see text" area).
Old 25th November 2012, 07:41 PM   #1933
necplusultra is offline necplusultra  Canada
tried dummy load with 2 12r 5w so tesetd with 24,12 and 6r load but the 6r load has too much current so the V out on both bibs drop by half.
bib power resisters are 2 x 3.9r with bjt version
seems to start drifting at about 400 so I think I'm on the edge with the current setting resisters. I may add another to get more current to see effect.
see text has 1 red led, 27r and 1 k trimmer with rest jumpered. I can play with voltage without problem
everything well sinked so nothing gets hot.
Old 25th November 2012, 08:15 PM   #1934
Salas's Avatar
Is the drift negative or positive, and does it stop at 0.1V?
Old 25th November 2012, 08:23 PM   #1935
drift is up and down but not stable at 5.25v like the functional bib. Also,it seems that turning the wiper does not change the V either when hooked up to buf3. I will perform more testing to try to figure this out. Since buf3 should consume about 450ma, I may be just on the threshold with those 2x3.9r power resisters. I started with 1 but that was not enough for the buf3 so I added another 3.9r and now one is perfect but the other is straying.
I'll try to post pictures later
Old 25th November 2012, 08:28 PM   #1936
Salas's Avatar
Looks like its on threshold. Normally V1.1 will drift (depending on Vref combination and temp) only a little negative. If with enough current it will still do the same weird stuff, then first suspect is the trimmer.
Old 25th November 2012, 08:31 PM   #1937
Salas's Avatar
Verify your current by measuring the voltage across the setting resistors and dividing by their combo value.
Old 25th November 2012, 08:54 PM   #1938
barrows is offline barrows
Default Yeah...
For the Buffalo you will want about 550-600 mA in the BiB CCS. This is a lot easier to achieve with 4 leds. Also, make sure you have adequate sinking. I relieved some heat in my set up by using an 8 VAC transformer so there is a little less voltage drop.
V/R in the current set resistor gives you the CCS current...
Old 25th November 2012, 08:56 PM   #1939
Thanks Salas,
This is indeed a learning experience for me.
So I added an extra 3.9r on the failing bib and now I get a constant 5.25 V. I'll measure the voltage accross these R's and calculate but it seems that the comnsumption would fall between 2x3.9 and 3 x 3.9. The functional bib is at 2x3.9r. I had to add an extra 3.9r on the other bib to make it work properly. It seems that my current setting R's should fall somewhere between 1.3 and 1.95R.
V accross one bib .72v / 1.3 = .553
V accross other bib is .93 /1.95 = .476
If I understand this correctly, previously I had .72/1.95 = .369 which is not enough for the buf3.
Also, if the b3 consumes 450, I should be adding an extra 150 for the bib for a total of 600ma. I would have to reduce the r on both to attain 600ma given that one v reads .72 and the other reads .93
Hope I got this right
So my question is why do I get so different voltages (.72 vs .93) on identical builds?
Old 25th November 2012, 10:05 PM   #1940
Salas's Avatar
Different Mosfet Vgs from sample to sample and/or less total Vf from Leds, samples vary also, even if matched the Jfet that runs them could be less for idss in one board. In one word: Tolerances.
SSLV1.1 builds & fairy talesHide this!Advertise here!
Legis' Horny Tales Legis Multi-Way 176 11th September 2017 12:21 PM
Any successful/unsuccessful tales of loading a large Coax in a front horn? POOH Multi-Way 35 22nd November 2015 08:58 PM
Fs: Salas SSLV1.1 BIB janos_904 Swap Meet 13 27th May 2015 08:36 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
