SSLV1.1 builds & fairy tales - Page 186 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 22nd October 2012, 02:38 PM   #1851
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The CCS normally saved you with current limiting. Just try with 1K dummy to confirm.
Old 22nd October 2012, 02:43 PM   #1852
roender is offline roender  Romania
roender's Avatar
As Salas said, nothing was fried as short circuit protection is one of the many advantages for a shunt power supply. And it comes free with the design ;-)
Old 22nd October 2012, 03:22 PM   #1853
Hi Salas, Roender and Tea-Bag
just did my reset and everything works like advertised. Thanks again...
Old 28th October 2012, 06:39 PM   #1854
pchw is offline pchw  United States
Quick question to the jfets selection.
The build guide says 3-5mA range, and it also says
A circa 4ma IDSS 9V testing JET gives you around 3mA.
My question is whether the 3-5mA range is the 9V testing reading,
or it is the prorated in-circuit IDSS?
For some reason, I have quite a few (50+% of a batch of 40pcs) at over 5mA IDSS using the 9V testing method. Can these be used by any means like at Q105?
Thanks!!
- Fred -
Old 28th October 2012, 07:45 PM   #1855
Idss is the current passing when Vgs=0 and Tj=25degC
The in circuit current has Vgs not equal to zero, but some -ve voltage.
Inserting the resistor in the source, with gate to the ground side of that resistor creates that -ve Vgs and gives rise to Id<Idss.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 28th October 2012, 09:46 PM   #1856
Salas's Avatar
Thanks!!
That's for IDSS on a battery out of circuit yes. Characterization for a parameter in other words. They can be used if you aren't planning a 40V+ reg. In an upper Vout range situation much current would make Q104 transistor hot (sinks Q105's feed, sees most of the voltage), Q102 hot by itself spanning the voltage distance to 4 LEDS potential. Still even in lower Vout range apps you should know that a strong Q103 will present higher voltage for same value voltage set trimmers and resistors. If it goes out of manageable revise resistance lower.
Old 28th October 2012, 10:27 PM   #1857
Thanks, Salas and Andrew.
I am about to start a 5V SSLV1.1 point-to-point wire build for JP's ES9023P Dac by
using the parts that I already have. My transformer is 9-0-9 which should work out to approx. 12.5VDC at C105. I think I am not at risk of overheating any transistors without major human mistake :-)
- Fred -
Old 29th October 2012, 11:10 PM   #1858
Default SSLV1.1 has supply for tube heaters?
Dear all,
Has anyone tried to use BIB to supply undirected heated triode heaters? Say 6,3VDC (1A)
Thanks for your help.
Old 1st November 2012, 03:12 AM   #1859
It is up and stable upon first switch, no BOO
Next is to parallel a couple resistor to R101 and R103 to hit my 250mA and 5V mark then hook up to the dac ....
- Fred -
Old 1st November 2012, 03:21 AM   #1860
Salas's Avatar
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1638 22nd May 2017 10:11 PM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
Copyright 1999-2017 diyAudio
