SSLV1.1 builds & fairy tales
Old 16th October 2012, 05:05 PM   #1841
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
The schematic is OK. Shows an optional Zener also that may had tricked you. Objectively yes, OSCON is a good filter. Subjectively not my preference there.
Old 22nd October 2012, 01:16 PM   #1842
ombudsmann is offline ombudsmann  Germany
Default Red LEDs not lit
Hi all,
I just happen to be in the middle of a SSLV1.1 board PSU build for a standard Pass B1 Buffer PCB (the original from Pass Labs). Target voltage is +18V single rail.
I already built one successfully for my phono pre-amp and had no issues at all. But for this one, the two red LEDs in the voltage reference area do not light up. The 4 green LEDs do. I used the calculator to get the right parts (although I don't really know the load current), used 15R/5W for R301, 2 Wima Mks 4,7 uF Caps for C303 and C301, 1K8 for R303 and a Bourns W502 5K trimmer. D301 jumpered. I used BYV28-200 diodes for D311-314 as rectifier that I had lying around (instead of the MUR120). Nichicon Gold Tune 4700uF 100V as C305 (polarity is correct)
I had no visible signs of bad soldering, so I thought it would be good to build a second board with a different set of parts to be sure there is no bad part involved (I had a second board and IRF+ set on hand). Unfortunately with the same result.
Since building a shunt regulator with Salas and teabags boards for a B1 has been done loads of times in the community, could anyone give me a hint where I went for the wrong path?
Any help appreciated,
cheers
Old 22nd October 2012, 01:33 PM   #1843
roender is offline roender  Romania
roender's Avatar
Most probably you are exceeding the CCS current with the load needed current, hence running into no juice for the shunt FET transistor.
Old 22nd October 2012, 02:12 PM   #1844
Thanks for the suggestion. That means lowering the value for R301 would do the trick?
Old 22nd October 2012, 02:18 PM   #1845
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I think the IRF9530 might be shorted. Measure voltages there, and all the T0-92 devices.
15R @ 18v should work, but 10R might be better if Roender is right.
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 22nd October 2012, 02:22 PM   #1846
Salas's Avatar
What is the dummy load used? That will say something certain about the set current sufficiency.
Old 22nd October 2012, 02:26 PM   #1847
The dummy load is 1R. Thanks for your quick response, amazing service!!!
Old 22nd October 2012, 02:29 PM   #1848
Salas's Avatar
1R is effectively a short circuit. Thumbs up if with 2 surviving regulators, but to simulate a B1 make that 1K 1W.
Old 22nd October 2012, 02:34 PM   #1849
Seems like we have found a source for my issues: myself. Thanks for your help, will see what I can rescue....
best
Old 22nd October 2012, 02:38 PM   #1850
Salas's Avatar
The CCS normally saved you with current limiting. Just try with 1K dummy to confirm.
SSLV1.1 builds & fairy talesHide this!Advertise here!
Legis' Horny Tales Legis Multi-Way 176 11th September 2017 12:21 PM
Any successful/unsuccessful tales of loading a large Coax in a front horn? POOH Multi-Way 35 22nd November 2015 08:58 PM
Fs: Salas SSLV1.1 BIB janos_904 Swap Meet 13 27th May 2015 08:36 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
