SSLV1.1 builds & fairy tales - Page 176 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th August 2012, 09:08 PM   #1751
wushuliu's Avatar
It's alright, Andrew seems to be safety first and 'an ounce of prevention'. Nothing wrong with that. Dirty job, but somebody has to do it! :P
Old 29th August 2012, 09:20 PM   #1752
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by AndrewT View Post
2C/W is hardly small.
I have used 5C/W and 7C/W and 10C/W in high current versions.
And I use 20C/W & 30C/W in ordinary DCB1.
And that 2C/W is only taking the one mosFET.
If all 4 mosFETs were fitted it would need to be bigger than 1C/W
Model your suggestion and let the Members see what you are proposing.
DCB1 hot rod at 1A runs at 0.5C/W per side. Looks like an F5 amp cousin. I said 40W parts can be safe at half their rating on GOOD sinking, then you come up with YOUR 2C/W definition of good sinking for a 2A biased semi. Before you paint a general answer as a ridiculous statement, its better you ask the other party what he defines as good sinking for the job first. Now that would be a serious approach.
Old 30th August 2012, 03:50 AM   #1753
Salas's Avatar
@ wushuliu about thermal design.
Each time you want to know how big a sink you will need with a device gather 3 pieces of information first.
1. Ambient temperature. I.e. how hot your house's inside runs on average.
2. How many volts and amps the semi(s) gonna have across.
3. Its junction to case thermal resistance spec RthetaJC.
Rules of thumb.
1. Don't allow beyond 100C junction temperature although your semi may have 125C max or more, that's for conditions safety margin and longevity.
2. Play down the sink's spec by 30% to cater for heat spreading non ideally on sink, semis mount as hot spots.
3. If the sink will be in a box add 20C to room temp. For free or top/side out of box correctly oriented heat-sinks in still air just room temp will do.
Example.
L.A. can be hot in the summer but you won't sit down listening long with more than 27C in your living room given you turn on the air-con or you prefer a Gin&Tonic outdoors instead. That chunky nice 0.5C/W sink you have been eyeballing has arrived. Lets start. Rule of thumb 2 makes it a 0.65C one. Assume you wanna sink two Mosfets on a positive polarity Bib 1.1 with same characteristics for simplicity. Say IRF9530s running at 1A CCS 10Vin-Vout and 20V 0.5A spare current output. That will set them at 10W dissipation each. 20W total. Sink will rise at 20W*0.65C/W=13C above ambient since its common to both semis. When you will close the box although it has some ventilation holes the heat builds up inside it. Rule of thumb 3 says 27C+20C=47C. 47+13=60C on your sink. You got those nice Sil-Pads to insulate the semis. Alas, there is transfer resistance. About 1C/W. You could use best CPU grade thermal paste smeared thinly on sink to smooth it out and go 0.7W/C or so but most will avoid the mess. So your 10W each dissipating Mosfet case is at 60+10=70C for 1C/W case to sink. Info 3 when you will look up IRF9530 gives ~1.7C/W RthJC. Thus for 10W the hot nucleus of each Mosfet is 17C hotter than its case. 70+17=87C. Under rule of thumb 1 is good to go. Others may relax the rules but that's how I go with sinks for staying carefree in hot rod.
Old 30th August 2012, 04:23 AM   #1754
wushuliu's Avatar
Thanks so much Salas. That is *very* helpful info. To be on the safe side I have also made sure to use computer fans with my hot rod builds.
Old 30th August 2012, 04:36 AM   #1755
Salas's Avatar
Forced cooling can enhance the sink's thermal rating dramatically, if the equipment are situated far enough and the fans run silently no to be a distraction.
Old 30th August 2012, 09:56 AM   #1756
Let's look at your 2.5A @ 10Vds using first 0.5C/W and then 0.2C/W for a heatsink for a lone 40W mosFET.
Ta = 40C, Rth s-a = 0.5C/W, Rth c-s = 1C/W, Rth j-c = 3.12C/W
Pq = 25W continuous.
Delta Ts-a = 25 * 0.5 * DFsink = 12.5 * DF, I'll assume DF for a 12.5C delta is 1.5.
Ts = 40 + 12.5 * 1.5 = 58.75C
Delta Tc-s = 25 * 1 = 25C
Tc = 58.75 + 25 = 83.75C
Delta j-c = 25 * 3.12 = 78C
Tj = 83.75 + 78 = 161.75C > 150C, outside manufacturer's specification.
We have not allowed for a rise in mains voltage yet. I'll do that when I consider the 0.2C/W sink.
DFsoa = [150 - 83.75] / [150 - 25] = 0.53.
This tells us that the 40W device can dissipate 21.2W when Tc is @ 83.75C
Now to the big sink sitting outside the chassis.
Ta = 30C, Rth s-a = 0.2C/W, Rth c-s = 1C/W, Rth j-c = 3.12C/W
Delta Ts-a = 25 * 0.2 * DFsink = 5C * DF, I'll keep the same assumption DF for a 5C delta @ 1.5.
Ts = 30 + 5 * 1.5 = 37.5C
Tc = 37.5 + 25 = 62.5C
Tj = 62.5 + 78 = 140.5 < 150C, within manufacturer's specification.
Now look at the mains voltage variation.
at nominal voltage the mosFET sees 10Vds.
Vout = 10Vdc, Vdrop = 10Vds, Vin = 20Vdc+[half of ripple], Vat rectifier = 20.7Vdc+{half of ripple] I'll guess that Vripple =500mV @ 2.5A of output
Vac at transformer = 20.95 / sqrt(2) = 14.8Vac
Now increase the mains by 6%. The Vac rises to 15.7Vac.
Vdc = sqrt(2)*15.7 - half ripple - diode drop = 21,2Vdc
This gives Vdrop = 11.2Vds
Pq = 28W continuous but relatively short term, maybe an hour or 30 minutes.
Tj = 30 + 28 * [0.2*DF + 1 + 3.12] ~ 153.7C > 150C
We still have to short the output to check if the mosFET can survive during this hopefully short term worst case condition.
Can anyone see why the original suggestion of >= approximately half Pdmax is a nonsense?
If advice and guidance is being offered, it seems to me that that advice should be based on fact or experiment.
The advice must not be based on some plucked out of the air number that happens in this case to NOT be suitable.
If there are any mistakes in my arithmetic, or a formula I have wrong, then please inform and I will correct the script. I want the information and the method of modeling to be right, for all those who see a need to simulate the actual operating conditions of their CCS mosFET.
Similarly, if you see a need for a bit more explanation within the script, then make suggestions.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 30th August 2012, 10:07 AM   #1757
Originally Posted by Salas View Post
IRF9530s running at 1A CCS 10Vin-Vout and 20V 0.5A spare current output. That will set them at 10W dissipation each. .........
this 10W for Pq cf. 88W device (~12% of Pdmax) is much more sensible and the sim shows a long term Tj of <90C.
No comparison to the earlier misguided advice of 50% to 62%.
Salas,
you have shown how to do it (model or simulate) rather than simply guess. I knew you could do it. What I can't understand is why you offered that 2A to 2.5A guidance in the first place and then tried to defend the situation when it was clearly wrong.
regards Andrew T.
Old 30th August 2012, 10:20 AM   #1758
Salas's Avatar
I did not offer any sinking guidance. Just commented on amperage pictured on a SOA chart. Someone could use a fan or a water cooler or stick it in the fridge. Nobody asked on how to sink that amperage on what sink he has got in hand. Your style, assumptions, and attitude are not appreciated. Don't address me in my threads again unless you want to be ignored.
Old 6th September 2012, 07:20 AM   #1759
cersepn is offline cersepn  United States
Dear Salas,
Thank you for your generous contribution of this marvelous power supply. Also very grateful to everyone for their posts in this thread too, it's been helpful to read all your comments. I'm about to start on my +5V, 150 mA power supply too. I think someone built a PS for his ODAC with the same specs as well. I just want to confirm a few things, please bear with me
1. Can I use 50VA 2x22V for my 5V out target? Or is it too much?
For 22VDC in, Excel calculator gives me estimated minimum heatsink rating of 3.27 deg/W. Is this a reliable figure? Should I run out to get a lower spec’ed 12-15V transformer so I don’t have to dissipate so much heat on Q301?
2. From excel calculations, R301 = 12.2 ohm, 3W (calculated 1.1W). Where do I buy an exact 12.2 Ohm resistor?
3. Is R303 = 220R (?) Referencing what Salas said earlier, “You need the 220R or a simple diode in series with the LEDs. You need to jumper the non used positions to close the series Vref circuit. Use a 33R dummy to simulate 150mA load.”
If 3. is correct, then to double confirm, for the Norton section, R303 = 220R, R305 = 1k Trimmer, 1x Red LED on EITHER D305 OR D306, and jumper EVERYTHING else in the Norton section?
4. R305 = 1K Bourns 3296 Y trimmer (Read people mentioning about replacing this with a quality, fixed resistor once trimmed resistance to target. How do I find out what resistance the trimmer’s at? Do I need to get z201/mk132 type or any will suffice?)
5. Is C302 and C304 = 220 uF preferred for digital? Or C302 = 220 uF and C304 = MKT; R307 = 1R better?
6. For C305, is 10,000 uF of this Panasonic alu cap model ok? I can’t get the 10,000 uF panasonic FC, nichicon muse and elna silmic types. Or should I get 4700 uF FC/muse/silmic?
Thanks in advance for all the help
Old 6th September 2012, 11:13 AM   #1760
Salas's Avatar
1. Use a proper secondary transformer 12-15 Vac.
2. Is 150mA your current source setting or your load consumption? Be sure you use more CCS than the load needs. Closest to target available R301 resistor values are fine. Leds and Mosfet will have tolerances too. The CCS setting in this application is just to cover the plan, no exactness plays any role.
3. Use a diode in same orientation as the ''see text'' PCB area Leds. It will give you a voltage drop that will be self set, when with a resistor it will depend enough on Q303's Idss that energizes the Leds. Its either you use 1k trimmer and one red led, or 2 red leds and a diode for 5V. The diode position can alternatively be a ~220R for easier filtration by C301 but it may give you hassle trimming it is the deal. Its a small chance it will be grossly off target with a 220R though. Don't go after 5V dead on, go after you are in your client circuit's acceptable power voltage area.
4. You better take it out of PCB after a setting is good and you need measure the set value to sub a resistor for. Measure from wiper to the leg it was installed towards R304. Get a Dale low ppm fixed resistor or analogous to upgrade from a trimmer.
5. 220-1000uF C301 are OK values for digital, MKT & 1R termination are OK.
6. Looks like a plain type Nichicon 1000uF snap-in that in the link. Get a 4700uF FC or Muse, it fits more than well for just 150mA.
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1634 31st January 2017 02:57 PM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
Copyright 1999-2017 diyAudio
