SSLV1.1 builds & fairy tales - Page 174 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 26th August 2012, 06:42 PM   #1731
Default Legato...
The Legato draws approximately 200 mA per rail: that is you need 200 mA from the positive regulator, and 200 mA from the negative regulator.
For the CCS current with the BiB regs, you will get good performance with 350-400 mA of current in the CCS for each (+/-) regulator.
Old 26th August 2012, 06:48 PM   #1732
Marra is offline Marra  United Kingdom
Thats how it reads to me two two's and a four wire connection
Old 26th August 2012, 06:51 PM   #1733
Better to connect the two regs together, locally and run a 3wire triplet to the circuit.
But, the remote sensing complicates the issue.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 26th August 2012, 07:17 PM   #1734
great
will do, 350 to 400 ma per reg.
can I connect the f0 and s0 together from +- regs and run dual triplets from 2 regs to device
thanks all
Old 26th August 2012, 08:42 PM   #1735
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
No worries... I have done it successfully before.
RC
Old 29th August 2012, 07:59 AM   #1736
wushuliu's Avatar
Is a 24v 2A build feasible at all (aside from heatsinking issue)?
Old 29th August 2012, 08:31 AM   #1737
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
You need change the 9610 with a slower but tougher IRF9520.
Old 29th August 2012, 08:33 AM   #1738
wushuliu's Avatar
Good to know. May use for a low power class d amp...
Old 29th August 2012, 08:38 AM   #1739
Salas's Avatar
Been used before with good reports.
Old 29th August 2012, 09:46 AM   #1740
merlin el mago's Avatar
How much A can give IRF9520?
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1638 22nd May 2017 10:11 PM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
Copyright 1999-2017 diyAudio
