SSLV1.1 builds & fairy tales
Old 25th August 2012, 08:13 PM   #1711
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Have you read the guide?
Is for digital or analog?
Old 25th August 2012, 08:16 PM   #1712
5V Vout Mosfet reg. 2 1.9V LED, 220 Ohm R303. Other parts jumper.
There is in 1st post a calculator to calculate the current, always is better x 2 or x 3, in your case 300 or 450mA
Old 25th August 2012, 10:18 PM   #1713
wushuliu is offline wushuliu  United States
wushuliu's Avatar
I am using bjt. No 220r correct? 2 led rest jumpered. I am getting 2v across 20Ohm dummy no change using trimmer.
Old 26th August 2012, 12:36 AM   #1714
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
You need the 220R or a simple diode in series with the LEDs. You need to jumper the non used positions to close the series Vref circuit. Use a 33R dummy to simulate 150mA load. Set CCS for 200mA minimum. Your now dummy asks for 250mA you are possibly chocking your CCS setting. Find your CCS current by measuring voltage drop across your setting resistor and dividing by its value.
Old 26th August 2012, 02:28 AM   #1715
wushuliu's Avatar
Ah, thank you. I was indeed choking the current.Ok so I have BJT, 1k trimmer, 220R and 2Leds. I am getting 300mA w/ 4R 12w and 5.21v out. with trimmer turned all the way. How do I reduce to 5v proper?
Old 26th August 2012, 03:15 AM   #1716
wushuliu's Avatar
Never mind. Figured it out. Thanks again Salas.
Old 26th August 2012, 03:27 AM   #1717
Salas's Avatar
What is it built for?
Old 26th August 2012, 03:44 AM   #1718
wushuliu's Avatar
Odac...
Old 26th August 2012, 12:08 PM   #1719
qusp is offline qusp  Australia
qusp's Avatar
haha an interesting mix, the designer must think you very foolish when surely USB power is good enough… hehe
Old 26th August 2012, 12:24 PM   #1720
coolhead is offline coolhead  Malaysia
Originally Posted by wushuliu View Post
Odac...
Sound better or worst or nothing change?
SSLV1.1 builds & fairy talesHide this!Advertise here!
Legis' Horny Tales Legis Multi-Way 176 11th September 2017 12:21 PM
Any successful/unsuccessful tales of loading a large Coax in a front horn? POOH Multi-Way 35 22nd November 2015 08:58 PM
Fs: Salas SSLV1.1 BIB janos_904 Swap Meet 13 27th May 2015 08:36 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
