SSLV1.1 builds & fairy tales
Old 6th July 2012, 11:13 PM   #1601
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by mjock3 View Post
Heat sinks I am using are Aavid Thermalloy 8C/W P/N 531302B02500G
Tiny in any case. How hot is the sink itself?
Old 6th July 2012, 11:17 PM   #1602
Salas's Avatar
Here's a picture
Mount the Mosfet higher on top mounting hole. Half its back ain't touching it seems. That can explain it if I see well.
Old 6th July 2012, 11:18 PM   #1603
mjock3 is offline mjock3  United States
I is hot. How much larger sink do I need? Sorry I thought they were ok.
Old 6th July 2012, 11:19 PM   #1604
OK I will try that. Later tonight. Thank you.
Old 6th July 2012, 11:23 PM   #1605
Salas's Avatar
You could do OK if something like 60-65C can be measured on them after CCS setting for the purpose, dummy, and mounting are good. I generally prefer no more than 50-55C for long term, heatwave periods etc. but ~150F on sink itself is decently reliable for such semis.
Old 6th July 2012, 11:23 PM   #1606
Salas,
I also bought some heatsinks that are 5C/W, would that help?
Old 6th July 2012, 11:24 PM   #1607
Salas's Avatar
How much voltage there is across the blue 2.5R ?
Old 6th July 2012, 11:26 PM   #1608
It was 2.45 volts.
Old 6th July 2012, 11:26 PM   #1609
Salas's Avatar
Salas,
If they mount better use them. Contact quality between semi's full back and sink is of main importance, think about the lengths overclocking PC users go for CPU compounds, optimal spread, you get the importance, same stuff but more tolerable here.
Old 6th July 2012, 11:29 PM   #1610
Salas's Avatar
It was 2.45 volts.
0.98A if it is 2.5R spot on, so no mistake there. Should be the mounting back gap. Solve that first. Was the dummy hot also? I wanna know that current flows to dummy for sure too.
SSLV1.1 builds & fairy talesHide this!Advertise here!
Legis' Horny Tales Legis Multi-Way 176 11th September 2017 12:21 PM
Any successful/unsuccessful tales of loading a large Coax in a front horn? POOH Multi-Way 35 22nd November 2015 08:58 PM
Fs: Salas SSLV1.1 BIB janos_904 Swap Meet 13 27th May 2015 08:36 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
