SSLV1.1 builds & fairy tales
Old 22nd June 2012, 01:36 PM   #1491
R.I.P.
I am inclined to say neither. Just ensure the PSU behaves properly.
However the "golden eared Members" say otherwise.
regards Andrew T.
Old 22nd June 2012, 02:32 PM   #1492
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hehe... that depends on what you are powering with the shunt
RC
Old 22nd June 2012, 02:47 PM   #1493
merlin el mago is offline merlin el mago
merlin el mago's Avatar
+1
Old 22nd June 2012, 04:53 PM   #1494
samoloko is offline samoloko  Bulgaria
1) digital chips analog and digital 5V
2) DAC analog output stage
3) preamplifier
Old 22nd June 2012, 05:26 PM   #1495
barrows is offline barrows
Default sam:
3) preamplifier
I think we need to agree that numbers 2 and 3 above are the same as far as power supply requirements-there are essentially no differences in the needs of a DAC analog stage and a preamp analog stage.
Old 23rd June 2012, 12:22 AM   #1496
alazira is offline alazira  United States
alazira's Avatar
Default Vref vs Vout influence
which one of the Vref and Vout caps gives more influence
I find the Vref caps make more of a difference. My
Old 23rd June 2012, 11:32 AM   #1497
You aren't alone: welcome to the "Golden Ears Club"
Also is very important low ppm Vref resistance avoiding the trimmer to ensure no drift & no change of resistance due to the hot temperature of the regulator.
Old 23rd June 2012, 11:35 AM   #1498
R.I.P.
Originally Posted by merlin el mago View Post
........... very important low ppm Vref resistance avoiding the trimmer to ensure no drift & no change of resistance due to the hot temperature of the regulator.
have you compared the difference that a 5ppm vs a 50ppm resistor would make to the "change" in output voltage.
Have you compared these "resistor" tempcos to the semiconductor tempcos?
Balderdash !!
regards Andrew T.
Old 23rd June 2012, 11:54 AM   #1499
I compared a trimmer vs a low ppm Vref resistor.
How do you say "Balderdash !!"
Old 23rd June 2012, 12:10 PM   #1500
R.I.P.
let's suppose the resistor sees a dynamic temperature change of 20C degrees due to varying signal.
The 5ppm resistor will have a dynamic change in resistance of 100ppm, the 50ppm resistor will have a dynamic change in resistance of 1000ppm or 0.1%
That change will result in possibly as much as 0.01% change in the output voltage if no other measures were in place to lower the impedance.
But compare the change in semiconductor parameters. They completely swamp these tiny resistor value changes.
If you now look at the ambient temperature changes in the PSU, you will find that the resistor change in resistance cannot be measured as a change in output voltage. It holds at it's new value. That new value might be 0.5% higher than when cold, or could be 0.005% higher than when cold. But you cannot measure that drift change because it is completely swamped by all the other changes in voltage. You cannot hear the drift change in resistor resistance for exactly the same reasons. 5ppm or 50ppm does not affect the sound at an amplifier fed with the regulator.
We hear AC we cannot hear DC.
regards Andrew T.
SSLV1.1 builds & fairy talesHide this!Advertise here!
Legis' Horny Tales Legis Multi-Way 176 11th September 2017 12:21 PM
Any successful/unsuccessful tales of loading a large Coax in a front horn? POOH Multi-Way 35 22nd November 2015 08:58 PM
Fs: Salas SSLV1.1 BIB janos_904 Swap Meet 13 27th May 2015 08:36 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
