SSLV1.1 builds & fairy tales
Old 2nd August 2011, 04:47 PM   #111
manamanam is offline manamanam  Greece
Originally Posted by Salas View Post
Yummy.
And thousands of miles away..
Dr. Spock, beam for me some of them up!
Old 2nd August 2011, 05:38 PM   #112
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
There should be some happier Vf generic ones in the shops by chance if someone looks with the DVM on diode setting. There is also the odd blue one to mix which is high Vf, but I would be hesitant due to they are invariably noisier. What Vgs your IRF610 has at that current? One member had a 4.7V reading at about the same current region for instance.
Old 2nd August 2011, 06:19 PM   #113
mravinsky is offline mravinsky  Europe
If you are speaking about my measurements, they were with 4.7R resistors, because the departure point was about 2V, nothing like 1.49 or 1.1V. (In fact I have ordered lower values to test, but I suspect that it could be difficult to arrive to 400-450mA and 600-625mA for buffalo+tridents almost impossible with this configuration)
Iīve tested with theoretically yellow 2.4V Leds, but the reading for this strings (3 Leds) is also 5.7V, I donīt know why.
Old 2nd August 2011, 06:26 PM   #114
Now running CCS @510mA with R201=1Ω, voltage across R201=0.51V.
IRF610 Vgs=5.15V
Old 2nd August 2011, 06:42 PM   #115
Salas's Avatar
Good, manamanam. Guys, are you sure those DACs actually draw so much? Did anybody put a DVM in current mode and in series with one rail? IRF610s look like rising Vgs easily, and there are ways we can kick our Vref difference to Vgs, but is it really needed, or too much will go on sinks?
Old 2nd August 2011, 06:47 PM   #116
Tridents are shunt regs, AVCC reg is shunt reg too.
Total 5 shunt regs feeding the DAC.
Total current about 450mA.
Old 2nd August 2011, 06:48 PM   #117
Salas's Avatar
Yes, but are you sure that they draw 450mA or more per rail, or is it a total +/- spec?
Old 2nd August 2011, 06:57 PM   #118
The DAC needs only one 5.0 to 5.5v positive rail, and it is measured drawing 450mA.
The tridents and AVCC regs provide 3.3V and 1.2V for the DAC chip.
Dual rail power supply is needed for the I/V stage.
I don't have the I/V in my hands yet, but according to:
http://www.diyaudio.com/forums/twist...ml#post2517425
it's 200mA per rail when idle.
Old 2nd August 2011, 07:03 PM   #119
Salas's Avatar
So why you go 500mA for the negative and not 300mA?
Old 2nd August 2011, 07:09 PM   #120
Just checking its limits in case that the I/V draws more current.
On the manual it says that it draws a constant current of 350mA.
So i will finalize settings when i measure the real thing.
100mA on top of consumption is enough?
SSLV1.1 builds & fairy talesHide this!Advertise here!
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1661 31st January 2018 12:53 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
