SSLV1.1 builds & fairy tales
Old 14th May 2012, 09:11 AM   #1121
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Im about to order some parts, but I am looking at BL grade 2sk117, will this matter or is it a must to use the lower Idss parts?
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Old 14th May 2012, 09:13 AM   #1122
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
It matters, better use GR.
Old 14th May 2012, 10:21 AM   #1123
Thanks Salas, I need to find some then.
Old 15th May 2012, 11:55 AM   #1124
merlin el mago is offline merlin el mago
merlin el mago's Avatar
If you don't find ask Tea-Bag
Old 18th May 2012, 06:03 PM   #1125
Extracted from BiB guide Rev.2:
"You could use instead a Zener based configuration. Will give a fixed low drift voltage setting. Add R303 220R 1/4W to aid noise filtering, jumper the LEDs and the trimmer positions. Use 220uF C302 50V. Not an MKT. Zeners need more filtering. There will be additional 0.6V from Q304 Vbe and R303's Voltage drop. VR303=R303*IQ303. Factor in the extra voltages. Q303 JFET will be weaker for IDSS in circuit from what you had measured with a 9V battery. A circa 4mA IDSS 9V testing JFET gives you around 3mA. If you still want keep the LEDs for indication, they will be adding their Vf too as in the first example. The higher the target Vout the more reliable a Zener reference is for low drift VS a resistor reference."
My question is: wich is the minimum high target Vout to use Zener? Zener 0.5W wich voltage? If trimmer is jumped how adjust the Vout? I ask because I'm doing regs. for 30 Vout.
Old 18th May 2012, 06:23 PM   #1126
Salas's Avatar
The Zener option is for those choosing to avoid a trimmer. You should think of adding the Leds voltage, 1.3V from Vbe and drop on a 220R at Zener's tail, plus the Zener voltage itself to know VoutTotal.
Old 18th May 2012, 06:38 PM   #1127
Sorry for my English, I don't understand you very well, could you elaborate?
Old 18th May 2012, 07:16 PM   #1128
qusp is offline qusp  Australia
qusp's Avatar
the zener is noisier, but has a fixed voltage that is possible to be higher and possibly more stable than the largest possible total of the series LEDs on the board, so you can avoid the trimmer.
so for your total add the 1.3v drop from vbe + total drop from the LEDs + the drop from the 220r on the zeners tail for the total reference voltage
is that about right salas?
Old 18th May 2012, 07:41 PM   #1129
Salas's Avatar
Yes, only that 1.3V represents the Vbe AND the 220R drop.
Old 21st May 2012, 02:15 PM   #1130
samoloko is offline samoloko  Bulgaria
Salas
can we use SSLV1.1 for digital power supply DACs
what do you think about John Svenson simple regulator http://www.diyhifi.org/forums/viewto...3228a0f#p30415
SSLV1.1 builds & fairy talesHide this!Advertise here!
Legis' Horny Tales Legis Multi-Way 176 11th September 2017 12:21 PM
Any successful/unsuccessful tales of loading a large Coax in a front horn? POOH Multi-Way 35 22nd November 2015 08:58 PM
Fs: Salas SSLV1.1 BIB janos_904 Swap Meet 13 27th May 2015 08:36 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
