SSLV1.1 builds & fairy tales - Page 110 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th April 2012, 07:51 AM   #1091
Originally Posted by merlin el mago View Post
For digital as Vref I use lytic as per Salas advice in the manual BiB.
Arcotronics MKP 10uF 63V
Arcotronics R75?
Old 29th April 2012, 10:11 AM   #1092
It looks like the 200mVgs change is telling you that the 610 does not like what you are asking.
Add in mains voltage changes and the 610 is going to struggle to maintain CCS current constancy.
Basically, I am still disagreeing with Salas.
Your Input voltage rejection ratio is going to suffer, because the Vgs is approaching the Vds of the pass device.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 29th April 2012, 02:10 PM   #1093
merlin el mago's Avatar
Originally Posted by manamanam View Post
Arcotronics R75?
Sorry is MKT Aroctronics R60
Old 29th April 2012, 04:23 PM   #1094
So it's a MKT, not a MKP. Makes sense you got better results with the Auricaps.
Old 29th April 2012, 08:22 PM   #1095
RCruz is online now RCruz  Switzerland
nhinstruments
RCruz's Avatar
While waiting for BiB round 2, I decided to try it in p2p style.
I am posting the layout hoping all connections are ok.
RC
Old 30th April 2012, 05:57 PM   #1096
nhinstruments
RCruz's Avatar
I wonder what should be the best values for R3 and R5 to get 14Vout ?
RC
Old 30th April 2012, 08:16 PM   #1097
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Its all in the guides, but a quick answer would be about 5K total series variable resistance in the Vref. Check for ~3mA IDSS Q3. That one you show has those resistors in parallel than in series and misses one or two LEDS VS the PCB one. Will work also, if maybe a bit driftier.
Old 1st May 2012, 08:04 PM   #1098
Arcotronics R75?
Do you know where can buy them?
Old 1st May 2012, 09:55 PM   #1099
pellesmil's Avatar
Hi
have started the build of a single positive bjt reg ( i have a IRF reg to but am building the BJT first).
I am feeding it with a 50va 18v trans. and need 210ma to feed my Dynavector P-075mk2 RIIA, i have used a 6 AH led battery with great success (even when it drains fast)
I built the reg with 4 green leds and a 10ohm R301 that gives me 300ma ccs
it worked smooth with my 240ma dummy load.
But when hooking up my RIIA it refuses to bring it up to 12 v it stops at about 2.5v, when "helping" it whit a battery it starts and works well.
Raising the CCS to 400ma 6,6ohm the RIIA starts if the regulator is powered up and running without load and hooking up the load later.
Raising the CCS again to 536ma 5ohm it starts both hooked up at the 12V side when plugging in the A/C and when hooking up the 12V
So here comes the essence:
-Can i run above 500ma CCS when i only need 210ma? (meaning is it conductive to sound quality)
-Would a different setup work better? am running 4,7uf MKT C304 and BJT
-Would it be wise to use good (Dale maybe) 1ohm r307 in the Zobel ? (and other resitors as well)
Per
Old 1st May 2012, 10:11 PM   #1100
Salas's Avatar
Is it a high start up current need from the Riaa, or some instability between the reg and Riaa? It takes to watch it with ameter and oscope to really know. If its a matter of needing more current, using >500mA is no constraint if your sinks are still under 60C. And it is conductive to SQ, though anti energy star. :-) Are there any high value electrolytics on the Riaa +V that they try charge up and demand much instant current? Maybe a good idea to delete them. Don't know if 1R R107 can be picked up quality wise. But it should be present with MKT Zobel. What do you mean helping it with the battery? Touching the battery between V+ & GND Riaa and then it kickstarts?
GB Thread for Salas SSLV1.1 BiB shunt reg Tea-Bag Group Buys 1637 Today 12:57 PM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
Some VX.2 Builds CSS/XBL CSS 0 11th April 2013 05:34 PM
so who here builds amps amp builder jb Tubes / Valves 29 15th July 2005 08:23 PM
Copyright 1999-2017 diyAudio
