SSLV1.1 builds & fairy tales
Old 20th February 2012, 12:13 PM   #1011
hochopeper is offline hochopeper  Australia
Originally Posted by merlin2069er View Post
What is the size of the sslv1.1 board? I'd like to fit a couple into a hammond case if possible.
Per salas guide:
Three 128x42x1.6mm LWH double layer plated through holes 2 OZ copper boards. 2 positive and 1 negative polarity sections arranged as one 128x126x1.6mm entity with grooved lines between them.
Can break apart easily in sections to be used/placed individually or not.
If you're talking hammond extruded cases you may be limited by height of filter caps that you chose ...
Old 20th February 2012, 12:21 PM   #1012
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Yup. Hammond extruded case. I'll see if they fit. I might want to get a set (of 3) anyways. Are they still available?
Old 20th February 2012, 12:27 PM   #1013
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Hydra headed has been discussed as a doable option in the past but never tried.
PCB dimensions are mentioned in the manual.
Old 2nd March 2012, 06:19 PM   #1014
kerux is offline kerux  United States
I built a 15+ and 15- volt Bib boards for my Bugle phono amp. The R101 is 7.5ohm and the R201 is 5ohm. Now, I have BIB boards for both my phono amp and my lightspeed volume control going to my Tubelab SSE. The sound improvement with these boards is amazing. The music is so clean and clear. Led Zeppelin's Kashmir never sounded so good to me. Thanks Salas for this amazing shunt regulator.
Kerux
Old 2nd March 2012, 06:25 PM   #1015
Salas's Avatar
You are welcome.
Old 10th March 2012, 05:24 AM   #1016
grufti is offline grufti  United States
grufti's Avatar
I tried to access the build guide on the website where it currently resides. No such luck.
ul.to - Not available ...
... returns only an error message: ul.to - Not available / "Our service is currently unavailable in country. We are sorry about that."
I am sorry too because I would like to access the guide. The country that is not being served in this case is the United States of America.
Old 10th March 2012, 06:49 AM   #1017
acidbrain is offline acidbrain  Netherlands
acidbrain's Avatar
With the ACTA & SOPA a torrent or magnet link could be an alternative. Anyhow, grufti you have a mail.
Old 10th March 2012, 09:52 AM   #1018
Salas's Avatar
Suggest an upload service that you freshly check is still accessible to US IP numbers and I will upload it there too.
Old 14th March 2012, 06:43 PM   #1019
DaveDaGr8 is offline DaveDaGr8  Australia
How about Google Docs ?.
I just tried to download and was met with a brick wall.
Old 14th March 2012, 07:17 PM   #1020
Salas's Avatar
Try to read it on Google. Let me know.
SSLV1.1 builds & fairy talesHide this!Advertise here!
Legis' Horny Tales Legis Multi-Way 176 11th September 2017 12:21 PM
Any successful/unsuccessful tales of loading a large Coax in a front horn? POOH Multi-Way 35 22nd November 2015 08:58 PM
Fs: Salas SSLV1.1 BIB janos_904 Swap Meet 13 27th May 2015 08:36 AM
WTB : Salas SSLV1.1 BiB shunt CaNNA3IS Swap Meet 1 24th November 2013 09:43 AM
FS : 2 x Salas SSLV1.1 BiB PCB + 6 x IRF MiniKits korben69 Swap Meet 6 2nd July 2013 09:32 AM
