Are there any concerns about adding a virtual CT to a 5.0v filament winding to get two 2.5v supplies?
#2 |
For what purpose? What do you mean by 'virtual CT'? Do you want AC or DC supplies? Draw us a diagram.
#3 |
DF96,
Admittedly, I'm a rank amateur at this,my first attempt at building a tube amp. I started with a separate amp chassis from the PS chassis & tried to stuff two 2.5v & two 6.3v filament transformers into the amp chassis.The result was a rat's nest in the too small amp chassis.I'm trying to eliminate all four filament transformers from the amp chassis with filament power from the PT in the PS. The PT has a 6.3v8.0A winding I was hoping to use. I'd put a pair of 100 ohm resistors across the winding for a CT. Hopefully, I'd have two 3.15vac supplies I could pad down to 2.5vac for the 2A3 tubes. I hope my explanation is better than a sketch for your information. Frank |
#4 |
I made a typo with the 5.0v in the first post. It should have read 6.3v.
The 5.0v3A winding was too small for my 2A3 tube needs. |
#5 |
Isn't the 2A3 directly heated? If so, you can't have two sharing a heater winding unless they are wired in parallel (or possibly push-pull) as their cathodes will be coupled together. Even then it might not work as there will be AC between the cathodes. If you want to use exotic things like 2A3 then you have to use the right transformer.
#6 |
DF96,
Yes, they're directly heated. I'm aware that a 2.5vac winding can't serve two 2A3 filaments in parallel. I was hoping that each half of a 6.3vac winding would be sufficient isolation for each 2A3. Thank you for responding. Frank |
#7 |
It depends on how it is wound and terminated. Some 6.3V CT windings are actually two separate 3.15V windings - in that case you are OK. You would have four wires coming out of the transformer, two of which you normally combine to form the CT. If you only have three wires then it won't work.
#8 |
DF96,
So I'm out of luck with a transformer that even lacks a wired CT. I'll mount independent 2.5v transformers in the PS chassis. Thanks, Frank |
| Virtual unity gain using voltage divider? | Artie | Chip Amps | 8 | 16th March 2010 11:20 PM |
| transformer with ct or non ct? | galih | Chip Amps | 7 | 7th December 2009 05:08 PM |
| How can I divide the I2S signal with 2pcs TDA1541A (one per channel) | cartman | Digital Source | 4 | 3rd July 2006 01:00 PM |
| virtual crossover | swirv | Multi-Way | 3 | 13th January 2004 06:19 AM |
| Page generated in 0.39275 seconds (-55.25% PHP - 155.25% MySQL) with 10 queries |
