I know the 2A3's in a stereo SET must have independent filament power supplies, but I don't remember seeing any rules against running the preamp & driver tubes of both channels off of a single filament power source (when either AC or DC).
Is this practical or a no-no? |
#2 |
If the filament is the cathode then the tube requires separate power supplies. If it has an indirectly heated cathode it is not much of an issue.
#3 |
These preamp & driver tubes are 6SN7/7N7 indirect heated cathodes.
Will combining the left & right channels cause any problems of any magnitude? Combining the heater supplies will simplify the wiring for me from a separate PS. Thanks for the response. |
#4 |
you can combine those
#5 |
That's great news!
I'm in the throes of simplifying the wiring of my stereo amp that wound up with a rat's nest of wiring because I included two 2.5v transformers & two 6.3v transformers & rectifiers in the undersized amp chassis. Now I'll modify the separate PS chassis for the filaments supply using the 6.3v/3A PT winding for all 4 preamp/ driver tubes. Thanks again. Last edited by dobias; 7th July 2011 at 05:02 PM. Reason: change 8 to 3A |
| combine stereo input for TDA 7294 single chips | rifky | Chip Amps | 3 | 6th March 2011 01:05 AM |
| How to spilt one channel out from stereo for woofer | chchyong89 | Chip Amps | 16 | 24th April 2009 01:11 PM |
| Using 5 channel receiver for stereo sub and speakers | renfrow | Subwoofers | 7 | 21st September 2006 02:17 PM |
| Right Channel not working on Stereo reciever | nicku1302 | Parts | 1 | 29th November 2005 02:32 AM |
| question for those using subs with 2 channel stereo | Jim85IROC | Subwoofers | 15 | 26th March 2004 02:38 PM |
| Page generated in 0.07337 seconds (71.46% PHP - 28.54% MySQL) with 10 queries |
