Go Back   Home > Forums > Amplifiers > Power Supplies
Old 6th July 2011, 07:26 PM   #1
Boscoe is offline Boscoe  United Kingdom
Default Transformer problems...
Just puzzled me this one a bit. I have this toroidal transformer that I got from an old power amp that I intend to use on a new project but the voltages are way too high so I intend on taking a few windings out. First I powered it up to see exactly what the rail voltages were but I just get the sound of it melting. I immediately turn in off. It was only on for less than a second my finger was still on the switch. I check the windings to make sure I get the right ones, although it has no info on which ones which I assume that the primary windings are the ones with a much smaller gauge wire then the secondary larger wire. I have made sure I'm not powering the 110V winding either. There was a tiny winding on top of the primary and secondary but this had only 20 turns with a tiny gauge which I have taken off.
By the size of it I would guess it would be about 1000VA although I wasn't using any soft startI didn't think I would need it for a little bit of testing. Could this be the problem?
Thanks.
I thought about it once, but then thought again.
Old 6th July 2011, 07:40 PM   #2
Power it up from a low voltage transformer around 12 volts. Then you can measure all the windings voltages and see what is who, when and where!
If it still heats up, use an oscillator and resistor to find the shorted winding. The one that has the least difference between DC and AC resistance and impedance is most likely it.
Old 6th July 2011, 08:07 PM   #3
Use a "light bulb" tester, 100 watt bulb and no load on transformer. If all is OK, bulb should light at first, then go dim or nearly off.
Mike
Old 6th July 2011, 08:14 PM   #4
Nice one thanks folks.
Old 7th July 2011, 09:57 AM   #5
get into the habit of always keeping the bulbtester right next to your workbench so that you never try to start a part assembled project direct off the mains.
regards Andrew T.
Old 15th July 2011, 05:17 PM   #6
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
I´ve always used Ohm-meter to mesure active resistance of the transformer coils. The coil with greatest active resistance is commonly the 220-Volt one(i live on a continental part of Europe and we have 220 Volt supply). Off course I would mesure before powering it up. The idea with bulb is the one that I like the most-it is cheap,sure and very simple! I will remember that one!
Old 15th July 2011, 07:31 PM   #7
Elvee is offline Elvee  Belgium
It is indeed a very good one, but it will soon be over (or it already is, in my case):
the *$£* greens have succeeded in outlawing anything 60W or higher, and the rest will follow very soon.
Make sure to make huge stocks, otherwise you'll be caught naked, just like me.
Old 16th July 2011, 06:10 AM   #8
44250's Avatar
My country is always late in everything but in this case that is not so bad-we can still buy and use bulb-lights. If You need them,just give me number of peaces,power of light bulbs You need and your address at private message and I will send it to You. It is very cheap here and I can buy it "on every step". If I am not wrong,the flag at Your profile is a Belgium flag. I have a brother in Belgium and he is comming soon at vacaton here,so I can send it by him to You in Belgium. I would give him the bulbs and your address an he would post it to you. Greetings!
Old 16th July 2011, 03:00 PM   #9
Hi Everyone, while we're on this side track, you might want to look at this:
Phase-out of incandescent light bulbs - Wikipedia, the free encyclopedia
Mike
Old 16th July 2011, 03:20 PM   #10
Thanks, it's very kind of you.
You may receive a private message one of these days
Where you buy iron transformer core for DIY audio transformer tarsik Tubes / Valves 10 27th December 2011 08:15 PM
Dynaco 440 Transformer Cathode/Screen Taps 6P1P 6AQ5 UL transformer TheGimp Tubes / Valves 14 30th October 2011 12:20 AM
Oversized transformer - Any problems? parrymike Headphone Systems 8 18th July 2011 04:40 AM
MiniWatt N3 problems, oscillation thumping and RF/motor problems. Destroyer OS. Tubes / Valves 18 6th July 2010 12:14 AM
HUM problems one transformer two (or mor) psu's kscharf Chip Amps 6 19th April 2007 07:40 AM
Page generated in 0.08946 seconds (87.23% PHP - 12.77% MySQL) with 10 queries
