Problem with negative ALW superregulator - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 5th July 2011, 04:48 PM   #11
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Originally Posted by 5th element View Post
If you have a positive working version it is quite strange that the negative one doesn't. There are very few differences between the positive and the negative versions.
From memory the only components that require a differently wired circuit are the opamp and the pre regulator, everything else shares exactly the same pin out, the only thing necessary is reversing the polarity on the diodes/caps/voltage reference.
Yes, I checked the orientation of all components. I don't see any mistakes.
The manual about the testing procedure (with pre-reg disconnected !): connect +vsense and output; connect 0vsense and ground; connect dc powersupply to input regulator and to ground.
Make the above connections with the PSU powered off and ensure the above connections are made correctly - failure to do so WILL damage components permanently
Old 5th July 2011, 05:15 PM   #12
5th element's Avatar
Then do as Jan has suggested and measure the various components to check for any problems.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
ALW Regulator Version Changes-Q for ALW fmak Solid State 0 19th February 2006 04:39 PM
Strange Power Problem, no negative rail? Adam M. Chip Amps 16 15th September 2004 02:27 AM
dual voltage SuperRegulator? hegestratos Solid State 22 17th May 2004 04:05 PM
negative alw super regulator problem piewie Solid State 9 2nd May 2004 10:28 AM
Copyright 1999-2017 diyAudio
