SMPS with split rail output for Class D?
Old 30th June 2011, 07:54 AM   #1
eem2am is offline eem2am
Banned
Default SMPS with split rail output for Class D?
If an SMPS was being designed to supply a Class D amplifier……..would it make no sense to have a split rail output, since an SMPS can be designed to have a high voltage output without resorting to split rails (unlike a 50hz mains transformer)?
Old 30th June 2011, 11:22 AM   #2
alexcp is offline alexcp  United States
alexcp's Avatar
It would depend on the amplifier that is intended to work with the SMPS being designed. Some Class D amps run off split rails (e.g. UcD), some use single rail (e.g. TI's PurePath).
BTW, it would make sense to ask all your questions in a single thread, not in three separate thread. That way, you'd get more coherent response.
SMPS with split rail output for Class D?Hide this!Advertise here!
Split rail supplys for Class D amplifiers? eem2am Power Supplies 8 1st July 2011 05:47 PM
Using split rail supply for single rail DC DanX Chip Amps 1 15th March 2008 05:18 PM
What causes Rail Capacitors to Swell and Split Open? confused256 Solid State 20 19th September 2006 06:30 PM
ad8610 class a bias +v rail or-v rail? crippledchicken Solid State 11 29th April 2004 07:35 AM
basic split rail PSU mcai7et2 Solid State 6 30th January 2003 11:10 AM
Copyright ©1999-2017 diyAudio
