Tony's latest traffo DIY build
Old 10th October 2017, 07:37 AM   #961
R.I.P.
Originally Posted by saminnografix View Post
sir tony may i ask if i can get 1500VA on the following toroid?
OD = 8"
ID = 3"
H = 6cm
i do not have a concrete formula on toroid...
thank you
sam
Try winding on a part of your proposed primary.
Say 200turns and then test it via a Variac to see how much current passes through that primary winding.
Plot the Ip vs Vp curve and see the typical "S" shape. Determine the maximum voltage that 200T primary can take without getting too hot (high current).
From that you can work out how many primary turns you will need to react againt the MAXIMUM voltage you have at home.
regards Andrew T.
Old 10th October 2017, 08:35 AM   #962
saminnografix is online now saminnografix  Philippines
thank you so much sir...
GodBless...
Old 13th October 2017, 03:40 AM   #963
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
500 VA isolation traffo for my bench top...230 volt primary to 0 to 100, 115, 230 volt secondaries...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 14th October 2017, 04:55 AM   #964
TonyTecson's Avatar
with end bells installed....
Old 14th November 2017, 06:48 AM   #965
Default traffo
sir tony may i ask another proposed project.
2"CL x 5" weight about approx.15.2 kg
prim. #14 AWG 230v @0.8t/v = 184t
sec. #11 AWG = 60Vac -0- 60Vac
thanks sam
Old 14th November 2017, 07:11 AM   #966
TonyTecson's Avatar
calculate if your chosen wires will fit inside the 1 in x 3 inches winding window...
way i look at it, more like #15 primary and #12 secondary...
Old 14th November 2017, 07:38 AM   #967
i thought that too but first, are my computations possible (power:core) ratio?
secondly the way i look at it as i have samples of number 14 wire
in a window of 1"x3" less the bobbin roughly i would take 7/8 x 2 3/4 allowable winding area, so based on actual #14 magnet wires can turn up to 38 in a 2 3/4 bobbin size. I multiplied 38 x 5 = 190, and 5 turns of #14 occupies about 3/8 of an inch.
next the available window left was 1/2 x 2 3/4 unfortunately i do not have #11 sample but as i look into your table turns per linear inch
enamel D.S.C. or S.C.C. D.C.C
#14 15.0 14.20 13.8 i used 14 turns per linear inch as presumption = it works
#11 10.7 10.3 9.8 i used 9 since i do not have sample to compare with.
the bottom line here are my interpretation and calculations based on your table correct?
thanks
regards
Old 14th November 2017, 08:02 AM   #968
TonyTecson's Avatar
the coil build up is what we look at, if that fits then you can go...
#14 has a diameter of 1.63 mm
#11 has a diameter of 2.3 mm
so how many layers for primary?
how many layers for secondary?
this will guide you to make the final decision...
Old 14th November 2017, 08:21 AM   #969
ok sir thank you for the quick reply
i used english system as i saw it on your table
using metric 25mm x 75mm
#14 actual size at hand was 1.83 into (75mm) 70mm on bobbin 70/1.83 x 5 layers = 191 turns
5 layers x 1.83 = 9.15 or 10mm
for #11 i used the next size guide say for example 2.7mm
#11 @ 2.7mm into a 70mm area will allow 25turns per layer, it needs about 4 layers that will also occupy 10.8mm
that is 9.15 + 10.8 mm = 20mm
by the way i am ordering #11 wire sample to have final measurement.
thank you sir.
Old 14th November 2017, 08:32 AM   #970
TonyTecson's Avatar
20mm is too tight, remember that calculations do not take into account winding factor,
if your calculations give you 20 mm as build up, do not count that that will be the actual buildup once you start winding, that is why i always end up with one size lower, better safe than sorry...
but if you can squeeze them in, why not? use mandrels and a big vise to flatten the coils so it fits...or g-clamps cam be used...
Tony's latest traffo DIY buildHide this!Advertise here!
tony's 6LU8 push-pull power amp build TonyTecson Tubes / Valves 31 7th April 2018 02:56 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 2 4th October 2017 01:03 AM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 07:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 12:34 AM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 11:50 AM
