Tony's latest traffo DIY build
Old 15th October 2011, 01:49 PM   #61
engel dela pena is offline engel dela pena  Philippines
jcatiwalaan,
if you are lucky,sir tony must be in pasig
otherwise he is in russia
or,,,,,,
you can follow his leads
do you have any rewinding experience before?
for a core 2in. center leg stacked to about 5.75inches you will need,
primary, 148 turns #13AWG copper wire,
secondary, 4coils quafillar wound 25turns #12AWG copper
note that i use american standard gauge, i know that in India, the British system is used, so make adjustment to suit your local conditions...
i based my computations on the assumption that you will be using the cheaper non grain oriented steel......
Old 15th October 2011, 03:39 PM   #62
wattaniya is offline wattaniya
hi tony thank u for the reply.
i searched and i found 2 into 3inch bobbin maximum so is this ok for 20ampere if not is this suitable for 10ampere, then can u tell me what is the winding turns of this and the guage.
thanks.
Old 15th October 2011, 11:05 PM   #63
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
How does one determine what flux the core can operate at? Steel looks like steel to me.
by the quality of the core on hand......
IME, there are 2 kinds, the GOSS steel will have a thickness of laminates at 0.35mm in general.....the non GOSS will have 0.5mm laminate thickness...
for the thin laminates i use 1T ~ 1.2T....
for the thick laminates i use 0.6T ~ 0.9T...
How does flux affect that formula I quoted?
Finally how does one get from core flux & voltage to primary turns?
higher flux densities need fewer turns, so for a given winding space you can use fewer turns which allows you to use bigger sized wires and so therefore you can extract more power because losses will be lower....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 15th October 2011, 11:08 PM   #64
TonyTecson's Avatar
Originally Posted by jcatiwalaan View Post
I need a power transformer for H900 80-40-0-40-80 V / 15A to 20A. Boss Tony, is it possible for you to make 2 units for me? How much will it cost? PM me pls..
Thanks and God Bless
regards,
John L.
you can reach me 628-2996......
Old 15th October 2011, 11:10 PM   #65
TonyTecson's Avatar
thanks.
that will work also.....i am curious to find out the quality of laminates you will use, what is the thickness?
if you can tell me we can make adjustments...
Old 16th October 2011, 04:49 AM   #66
i mean lamination thick am i right,
the thickness is 0.1mm.
thanks.
Old 16th October 2011, 09:12 AM   #67
R.I.P.
If one winds on the primary, can one test the primary current vs supply voltage to check that there are sufficient turns on the transformer to avoid the knee showing the onset of core saturation?
regards Andrew T.
Old 16th October 2011, 10:07 AM   #68
TonyTecson's Avatar
thanks.
are you sure? this is the first time i hear such material......do you have manufacturer's data sheets on your laminates?
Old 16th October 2011, 10:10 AM   #69
TonyTecson's Avatar
of course you can....in my designs i go for low magnetizing currents, that is why i go for low teslas....
Old 16th October 2011, 10:47 AM   #70
pieter t is offline pieter t  Netherlands
0.1 mm is well known material; meant for 400 Hz applications (power supply for planes for instance where weight matters).
Not well suited for a 50/60 Hz power supply transformer because the max T at those frequencies will be very low.
However you might use it for a very good output transformer.
Tony's latest traffo DIY buildHide this!Advertise here!
tony's 6LU8 push-pull power amp build TonyTecson Tubes / Valves 31 7th April 2018 02:56 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 2 4th October 2017 01:03 AM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 07:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 12:34 AM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 11:50 AM
