Tony's latest traffo DIY build
Old 4th September 2014, 11:16 AM   #661
kees52 is offline kees52  Netherlands
I have seen that the sheet for exel I did download do calculate a lot of possibilities of what is possible. Also it is said that flux density is important for how much I can get out, the laminels of my trafo are 0.5 mm thick and for welding I have read it is possible to use higher flux.
See picture of the calculations.
regards
kees
Old 4th September 2014, 11:28 AM   #662
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
0.5mm can also mean lower quality...be cautious running high flux...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 4th September 2014, 11:45 AM   #663
I have use 1.2 T I think this is oke, the trafo was a 1500 VA 220 v to 110 v of origine.
Old 4th September 2014, 11:48 AM   #664
TonyTecson's Avatar
how hot was it running then?
Old 4th September 2014, 11:54 AM   #665
If I did now I tell, I Have it from a scrapyard of how it is called in english.
I think I go for a inverter, I have the core,s, only I need a constant voltage source for Co2 welding with wire, I presume a smps with voltage feeback and current protection (above 130 amp it get in) is the way to go. electronics and pcb is no problem, however what chinese supplyer is to be trusted when order on ebay the IGBT,s and diodes.
I did see with current source inverter that only current is regulated and no voltage feedback make it open.
regards
kees
Old 4th September 2014, 11:59 AM   #666
TonyTecson's Avatar
okey, i suggest that you extend your primary winding, if you are running 230 volts, make a winding that can run 260 volts...several taps so you can reduce current if needed...
Old 4th September 2014, 01:44 PM   #667
Originally Posted by kees52 View Post
André
Not agree with this, read this paper.
Constant Current vs. Constant Voltage Output
Stick welding needs constant current source and MIG (wire feed) needs constant voltage (because of automatic feed of wire).
And so what to do with a inverter, have i build a normally power source with voltage feedback aca normal power supply and current protection.
The open voltage of my own MIG welder is 32 volts on max amps and has to be a voltage source the big coil in series with trafo act as the restistor to get this done.............
Thanks for the link.
I see I have CC type welders for stick (oil cooled) and for TIG (air cooled).
regards Andrew T.
Old 4th September 2014, 01:47 PM   #668
yes onlt stick and tig, mig needs voltage source, wire is the current regulation factor (speed and volts) some has even a wire feed who speed control also affect the output voltage (professional stuff)..
I my case a choke in series with trafo do the trick.
regards
kees
Old 4th September 2014, 04:04 PM   #669
I have calculate the trafo such that I have 140 amps on 21.2 volts like the welder has on manual, now it looks it fit and wire thickness etc is more normal.
I have use a flux of 1.35 T what is used for weld transformers.
program calculates load on output, so I think if i build the thing I get 32 volts open loop.
regards
kees
Old 5th September 2014, 04:54 AM   #670
johansen is offline johansen  United States
try a flux density of 1.7T and you'll have much more reasonable results.
most stick welders have 80 volts open circuit.
With either adjustable magnetic shunts for current control or an inductor with multiple taps.
Tony's latest traffo DIY buildHide this!Advertise here!
tony's 6LU8 push-pull power amp build TonyTecson Tubes / Valves 30 26th November 2017 01:11 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 2 4th October 2017 02:03 AM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 08:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 01:34 AM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 12:50 PM
