Tony's latest traffo DIY build
Old 8th March 2014, 08:42 AM   #571
AJT,
do you use a different flux for the different thicknesses and types?
regards Andrew T.
Old 8th March 2014, 09:21 AM   #572
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Originally Posted by AndrewT View Post
AJT,
yes, if the core material is M6 quality i use 1T,
if low quality i use down to 0.6T
if i do not know where the core came from, i assume it as low quality...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 4th April 2014, 06:50 AM   #573
rawbas is offline rawbas  Philippines
Hi Tony,
Nice to see this thread. I would like to ask for some help. I have a toroid trafo, and I wanted to rewind it but I am not sure what is the VA rating. Here is the dimension,
(od= 4.5 inches, id= 2.5 inches, h= 2 inches).
Ren
Old 4th April 2014, 09:25 AM   #574
TonyTecson's Avatar
Originally Posted by rawbas View Post
Hi Tony,
Ren
VA is about 300 to 350...assuming that your dimensions are bare core...
Old 4th April 2014, 09:25 AM   #575
Are those the iron core dimensions, or the overall size with the windings intact?
regards Andrew T.
Old 5th April 2014, 05:54 PM   #576
yes, it is bare core..
Thanks Tony.
Old 6th April 2014, 01:18 AM   #577
johansen is offline johansen  United States
no, that core is good for a lot more than 300 va.
you should be able to wind the primary with 230-245 turns of 15 awg wire, for 1.6-1.5T
about .5 ohms primary resistance.. 5 amps works out to 12 watts of primary copper loss at 720 watt load.
Old 6th April 2014, 01:23 AM   #578
TonyTecson's Avatar
i tend to be conservative in my traffo builds...for EI i seldom went beyond 1T, since EI cores available here in Manila are low quality ones, i operate them at 0.6T average...
i suppose you can get more out of that torroid, but question is at what temperature rise?
if you live in an area where ambient temperatures are in the low 20*C you can operate the traffo more aggressively
, otherwise in our place where ambient temperatures can go as high as 40*C, then you would tend to be conservative....
Old 6th April 2014, 01:29 AM   #579
TonyTecson's Avatar
this assumes 120 volt primary?
in our country 230volt is common...
Old 6th April 2014, 04:54 AM   #580
small transformers typically run copper losses at 2-10 fold the no load core loss.
since copper loss follows the inverse of flux squared assuming constant copper volume, well, you can find your own optimal operating point yourself.
but cutting the flux down to 1T to save 2 watts of no load loss, when you're going to burn 15? times that in the copper isn't really smart.
of course leakage flux is a problem, so don't try and run it at 1.8T...
yes, of course its for 120vac. double the turns and add 20% for 50 hz, 18 awg would be more appropriate
Tony's latest traffo DIY buildHide this!Advertise here!
tony's 6LU8 push-pull power amp build TonyTecson Tubes / Valves 29 8th June 2017 11:12 PM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 07:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 12:34 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 0 27th December 2010 10:59 PM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 11:50 AM
Copyright ©1999-2017 diyAudio
