Tony's latest traffo DIY build
Old 12th July 2013, 09:48 AM   #501
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
no, power traffo for a tube phono stage...
the other 3 are for a tube tone control amplifiers...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 21st July 2013, 06:34 AM   #502
TonyTecson's Avatar
i bought a component tester from RBT, a local DIY'er...
and since been doing testing inductance tests on traffos...
this is primary coil only...
with cores...
therefore the core's mu is about 428..
notice also changes in impedance with and without core, 48.6 from 17.9 ohms..
and now to compare deeco iron with z11 irons...
deeco iron is on the left and the z11 at the right...
choke has about 1400 turns #30 wire on a 3/4 x 1 inch bobbin...
inductance of coils is 49.5mH
deeco iron assembled and gapped showed 4.65H
z11 choke gapped and assembled showed 6.96..
this shows that for a given size, you will get more inductance out of a z11/M6 cores
than an H50 or deeco core...
Old 21st July 2013, 01:07 PM   #503
donnyab is offline donnyab
deeco core = mild steel ?
Old 21st July 2013, 11:06 PM   #504
TonyTecson's Avatar
silicon steel, gage #24, otoh, the z11/M6 is gage #29...
Old 23rd July 2013, 03:52 PM   #505
JOHN BALI is offline JOHN BALI  Indonesia
JOHN BALI's Avatar
Hi Tony, that's cool. I have similar tester
which core is better... the one with lower inductance or the higher one?
Thank you, I wish you happy
peace & G B U
Old 23rd July 2013, 05:56 PM   #506
Is that telling us that the resistor has 10uH of inductance?
regards Andrew T.
Old 23rd July 2013, 10:52 PM   #507
Mark Johnson is offline Mark Johnson  United States
It might be a Bourns inductor, part number 77F100K-TR-RC: (here is a link)
Old 23rd July 2013, 11:49 PM   #508
TonyTecson's Avatar
Z11/M6 gives higher inductance for the same iron dimensions...
Old 24th July 2013, 05:43 AM   #509
JOHN BALI's Avatar
no no... it's not a resistor
It is 10uH inductor, "inductor model resistor" that the seller says
Thanks Tony for these measurement,
now I can start to make my own transformer
with more confidence
peace & G B U
Old 24th July 2013, 05:46 AM   #510
TonyTecson's Avatar
yes, john, now we can put some numbers on what we do.....
for inductors that will have dc biasing, i suspect that inductance
will be lower, at least a half of what we measure...
Tony's latest traffo DIY buildHide this!Advertise here!
tony's 6LU8 push-pull power amp build TonyTecson Tubes / Valves 30 26th November 2017 01:11 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 2 4th October 2017 02:03 AM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 08:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 01:34 AM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 12:50 PM
