Tony's latest traffo DIY build
Old 22nd May 2013, 03:57 PM   #471
srinath is offline srinath  United States
If I pulled my traffo apart by grinding off the welds and instead of welding it back together, I can drill holes in the corners and bolt it with a bar across it then will it not have a proper magnetic field distribution ?
I am hoping to not try interleaving as my first experience. Thanks for all the knowledge.
Cool.
Srinath.
Old 22nd May 2013, 04:01 PM   #472
donnyab is offline donnyab
drill holes in the lams .. is it really worth the effort, sounds like a lotta hard work to me!!
Old 22nd May 2013, 04:40 PM   #473
Oooo I could just clamp it shut.
Would that work ?
Cool.
Srinath.
Old 22nd May 2013, 09:40 PM   #474
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
clamping could work though i haven't tried it...interleaving is the only way to do it unless you can tig weld it back...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 23rd May 2013, 01:37 AM   #475
In the transformer that I removed both the primary and secondary, the EI's have been welded in 4 lines. Like they would be if the EI's were stacked "EI" and "I Reverse E".
It also has the bottom plate plug welded into the plates on the one side where 1 pair of EI welds are. The stupid thing is, its not interleaved. Its all well "non interleaved".
The one I plan to use without pulling the primary apart has 1 set of EI welds and its not on the same side as the bolting plate.
I wouldn't be pulling it apart. 35 turns I can wind by hand.
Cool.
Srinath.
Old 23rd May 2013, 02:12 AM   #476
TonyTecson's Avatar
yes, there were many examples on YouTube to refer to....
Old 5th June 2013, 05:18 PM   #477
what have you done with Tony ?
Old 14th June 2013, 09:59 AM   #478
rolandong is offline rolandong  Philippines
Got time to do secondary winding...
Pinoy ikaw ay pinoy... ipakita sa mundo... kung ano ang kaya mo...
Old 14th June 2013, 10:04 AM   #479
Pig tails and cover with fish paper...
Old 14th June 2013, 10:06 AM   #480
Stacking 'E' laminates...
Tony's latest traffo DIY buildHide this!Advertise here!
tony's 6LU8 push-pull power amp build TonyTecson Tubes / Valves 31 7th April 2018 02:56 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 2 4th October 2017 01:03 AM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 07:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 12:34 AM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 11:50 AM
