Tony's latest traffo DIY build
Old 16th January 2013, 11:44 PM   #371
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
sent you email...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 17th January 2013, 12:43 PM   #372
jcatiwalaan is offline jcatiwalaan  Philippines
Originally Posted by AndrewT View Post
add a soft start circuit.
To Sir AndrewT and Boss Tony,
My problem has been solved after i installed the soft circuit in the primary of my 2400VA Torroid Transformer.
Thank you guys.
Best Regards,
John L.
Old 18th January 2013, 12:02 AM   #373
rolandong is offline rolandong  Philippines
Hi John,
How much did you bought the 2400kVA toroid?
Pinoy ikaw ay pinoy... ipakita sa mundo... kung ano ang kaya mo...
Old 18th January 2013, 02:16 AM   #374
Originally Posted by rolandong View Post
Hi John,
Hi Dong,
I ordered the torroid from Zhenshen China
P/N:ZMB1506: Input Voltage: 220V, Secondary: 4x40 (80-40-0-40-80) 20A 3200VA
Price:160USD/pc for 100pcs order quantity and 200USD/pc for one pc order quantity;
Our P/N:ZMB1505: Input Voltage: 220V, Secondary: 4x40 (80-40-0-40-80) 15A 2400VA
Price:115/pc for 100pcs order quantity and 150USD/pc for one pc order quantity
NOTE: The freight cost is 80USD here i Singapore.
I dont know the shipment to philippines.
I received te item 5 days after i made the payment.
Transformers manufacturer" <sales@inductor-transformer.com>
John L.
Old 18th January 2013, 04:13 AM   #375
TonyTecson's Avatar
Thank you guys.
Best Regards,
John L.
that's good to hear, with your traffo rated at 2400VA, primary currents can run to over 10amps, wire sizes for primary can be #12....that explains the almost 0 ohms dc resistance of the primary....
10ohm/50watt resistor is good for soft starting...
so if you are in Singapore, what probably happened was that you tripped the ELCB in your flat, in manila we do not have such regulations, only OL breakers, no provision for leakage current detection....
Old 18th January 2013, 04:18 AM   #376
Boss Tony,
Thanks for the explanations and suggestion.
Have a nice day sir!
John L.
Old 18th January 2013, 04:21 AM   #377
TonyTecson's Avatar
Hi John,
Roland,
there is a member here, Tubepro, he has a facebook page, ECONOLYTZ Philippines, he is in Hongkong but can get stuff from china easily, he sells torroid traffos, heatsinks, and power trannies, and many other mobile disco stuff....i met him once in raon...a swell guy....
Old 20th January 2013, 02:23 PM   #378
vedmitraa is offline vedmitraa  India
vedmitraa's Avatar
Default 2 small torrids I bought
Attached with are photos of 2 torrids primary already there , 240 volts 40 ampere and other 240 volts 60 ampere,will varnish them tape with glass fiber cloth and than secondaries, already bought 10 s.w.g. 15 k.g. for secondaries.
Failure in Experiment is key to success .Only right combination is needed.
Old 20th January 2013, 02:32 PM   #379
vedmitraa's Avatar
Default my crgo core collection
My bought cores crgo almost a ton torrid and E I for winding
Old 20th January 2013, 02:41 PM   #380
vedmitraa's Avatar
Default my modified traffo winding machine
This Machine I bought as scrap, cleaned it,increased the height of posts fitted it tuned it painted it, and fitted with D.C. Motor worm gear box,pulley and v belt now it is powered to wind traffos core section of 4" X 8" , 2 nos. 12 s.w.g. wires tightly it can pull with ease
Tony's latest traffo DIY buildHide this!Advertise here!
tony's 6LU8 push-pull power amp build TonyTecson Tubes / Valves 30 26th November 2017 01:11 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 2 4th October 2017 02:03 AM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 08:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 01:34 AM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 12:50 PM
