Tony's latest traffo DIY build
Old 11th January 2013, 08:33 AM   #361
wattaniya is offline wattaniya
hi tony thanks for the reply,
now i made the mandrel with concrete,(cement+concrete small stones) its perfect and accurate size .
with wood mandrel cant cut accurate size.
can i use 14awg instead 13 awg for secondary, and 17awg instead 16awg for primary?
Old 12th January 2013, 02:49 AM   #362
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Originally Posted by rolandong View Post
If allowing losses and targetting for 500VA, please tell me what copper wire size for primary and secondary (48Vac) and number of turns.
Thanks in advance.
sent you email, email me back and i will send you materials and a spreadsheet done by another member at a local site....Tony's Transformer DIY pics
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 12th January 2013, 03:01 AM   #363
TonyTecson's Avatar
yes, i believe that you are using the British standards for wires in India, so that you actually need smaller gauges....please look here....http://upload.wikimedia.org/wikipedi...auge_Chart.pdf
what you can do is take the diameter of the wires that are available locally to you and compare them with the table....
Old 12th January 2013, 10:25 AM   #364
awg = american wire gauge.
swg = standard wire gauge.
Convert both to millimetres and work with that conversion table to hand.
Standard Wire Gauge (SWG) conversion to metric
AWG to square mm Wire Gauge Conversion
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 16th January 2013, 09:45 AM   #365
jcatiwalaan is offline jcatiwalaan  Philippines
Default 2400VA 80-40-0-40-80 torroid
Mga sir need your advice:
May na order po ako ng torroid transformer from china.
Primary 0-220V 50Hz
Secondary 80-40-0-40-80 unload
2400VA
Weights 16Kg.
When i connected it to mains 240VAC, bigla po nag trip ang breaker namin sa bahay na 32A. I tried to measure the resistance of the primary, result is zero ohms.
Ano po kaya ang posibling dahilan? May issue po ba ang transformer? Or yung breaker sa bahay namin?
Paano ko po ma test yung transformer?
Need your advice mga sir especially boss Tony.
Thanks..
Old 16th January 2013, 10:19 AM   #366
add a soft start circuit.
regards Andrew T.
Old 16th January 2013, 10:49 AM   #367
TonyTecson's Avatar
Primary 0-220V 50Hz
2400VA
Weights 16Kg.
Thanks..
this is an English speaking forum.....i will let you go this time since andrewt seems to understand your post.....
did you test that traffo without anything connected to the secondary?
Old 16th January 2013, 11:35 AM   #368
Oopss.. My apologize to everyone for using different language.
Thanks sir Tony..
Yes Sir, i tested it without anything connected to the secondary.
If you dont mind,
I have the datasheet of the transformer, maybe You want to check it. So that you can advice me.
I just need your email sir.
Thanks a lot.
Old 16th January 2013, 12:03 PM   #369
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
Amazingly, Google is able to translate mixed languages.
Old 16th January 2013, 12:30 PM   #370
Thanks you very much Sir AndrewT for the input.
Is it normal for that transformer to have zero ohms resistance in the primary winding? Also in the secondary.
I am also waiting for Mr. Tony's advice.
________
John L.
Tony's latest traffo DIY buildHide this!Advertise here!
tony's 6LU8 push-pull power amp build TonyTecson Tubes / Valves 29 8th June 2017 11:12 PM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 07:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 12:34 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 0 27th December 2010 10:59 PM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 11:50 AM
Copyright ©1999-2017 diyAudio
