Tony's latest traffo DIY build
Old 3rd January 2013, 11:17 AM   #351
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Originally Posted by rolandong View Post
Cool Tony... those traffos popping out like daisy's...
you are responsible for shortage of 2" core and copper at deeco
Will be joining the party shortly as I have 4 pcs 200Watts output booster traffo EI core. Will be taking photos and exact measure of IE iron core in the next few days...
thanks rolandong......i have other sources too....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 10th January 2013, 07:44 AM   #352
wattaniya is offline wattaniya
Originally Posted by Tony View Post
you need a bobbin sized for 1 3/4 centre leg stacked to 4 1/2.....
you can get around 1740 volt amperes out of this...
primary turns = 233 turns #16 AWG magnet wire
secondary turns @30volts = 30 turns #13 AWG magnet wire, 4 coils, two bifillar windings....
in my country, the standard is AWG, please take note of this as you may have a different one in yours...
hi tony,
i am very sorry for late construction,
i bought the gage wires what u mention,
i cant wind the whole wires inside the window, its popping out, so any solution?
Old 10th January 2013, 06:45 PM   #353
johansen is offline johansen  United States
Originally Posted by nazirdigi View Post
hi tony,
please post a photo of what you got so far...
Old 11th January 2013, 12:25 AM   #354
TonyTecson's Avatar
hi tony,
as i said, wire gage numbers i use may not be the same as wire numbering used in India....
anyway, use wooden mallet to hammer out the bulge to make it fit, you can also use a table vise.....
Old 11th January 2013, 01:48 AM   #355
rolandong is offline rolandong  Philippines
Tony,
Here is 4 booster output traffo I wanted to recycle.
Instead of throwing this out in a junk, I was inspired by your good thread to try as well. Core size is only 1 & 1/4". If combined by 2's I can get 3.5" stacked each.
Please help me estimate possible VA we could get, wire sizes (primary & sec) and number of turns for 24-0-24Vac secondary. Is it better to combine all EI core into 5-7" stack? Or can I possibly have 2pcs 600VA which I can use for small amp like F5?
Pinoy ikaw ay pinoy... ipakita sa mundo... kung ano ang kaya mo...
Old 11th January 2013, 08:22 AM   #356
i will post image when my camera back soon from my friend,
i will try tony u suggested method.
Old 11th January 2013, 08:36 AM   #357
TonyTecson's Avatar
use wooden plates made of plywood about 1/2 inch thick on the coils, do not pound directly on the coils....also a wooden mandrel inside the bobbin to keep the dimensions okey....
Old 11th January 2013, 08:38 AM   #358
TonyTecson's Avatar
Tony,
1.25 CL x 3.5inch stack gives you about 595VA....
Old 11th January 2013, 08:43 AM   #359
If allowing losses and targetting for 500VA, please tell me what copper wire size for primary and secondary (48Vac) and number of turns.
Thanks in advance.
Old 11th January 2013, 09:30 AM   #360
Thanks in advance.
use my spreadsheet.
it is designed specifically for these kinds of questions.
everything is a variable.
http://johansense.com/bulk/spreadshe...merdesign1.ods
Tony's latest traffo DIY buildHide this!Advertise here!
tony's 6LU8 push-pull power amp build TonyTecson Tubes / Valves 30 26th November 2017 01:11 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 2 4th October 2017 02:03 AM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 08:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 01:34 AM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 12:50 PM
