Tony's latest traffo DIY build
Old 5th September 2012, 07:53 AM   #311
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
from the net, they are from china, materials available for sale in Manila are all imported from china....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 5th September 2012, 08:19 AM   #312
ISTPYRO is offline ISTPYRO  Portugal
Amazing work Tony. Can I ask you something? Your winding machine is manual, right? So, with one hand you give hand crank and with the other you do tension?
Another thing that I want to ask, but I did it before, and I'll ask again because no one answered exactly to my question, but now in other words.
@Tony or anyone else, when winding the trafo, if the turns, for example, of the primary finish at the middle of the bobbin/former, what you do? Recalculate the wire size in order to give more adequate fitting to the bobbin?
Old 5th September 2012, 08:32 AM   #313
TonyTecson's Avatar
yes, i had a wooden pulley made which i use to turn the bobbin when winding, my wife assist me in this instance with the wire feeding these big diameter wires....at other times i do it alone....
yes, that happens a lot of times, you have 3 choices, first is just go with it, the space can be used for auxilliary windings......second is just fill up the layer and recompute the secondary windings, you can do this when unsure about the quality of your core material.....third is to forgo and use the last filled up layer and then recompute for the secondary turns based on actual primary winding, this can be done if your core material is good quality like M6 goss steel.....
i hope this answers your question....
Old 5th September 2012, 08:50 AM   #314
The First I got it. The Second, what you mean is to fill up, with extra turns, the remaining layer (starting from where the turns have stopped) and then recompute the secondary windings and the Third, is almost the contrary, meaning, instead of filling up with extra turns, we remove the turns that have finished at the middle of the bobbin/former, in order to use only the turns that have filled the last layer. Then recompute again the secondary turns?
Is that it?
I am sorry for repeating, but is to be sure!
Kind regards.
Old 5th September 2012, 08:59 AM   #315
TonyTecson's Avatar
you got it....
Old 5th September 2012, 07:19 PM   #316
Aucosticraft is offline Aucosticraft  India
Originally Posted by Tony View Post
you got it....
So that was about mains transformer ( with CRGO) and not ferrite transformer. am I right?
To my knowledge, with ferrite core transformers number of turns and inductance are kept unchanged. But multiple primary are used for better coupling and getting leakage inductance low. pl. correct me if not so.
There is always a first time....
Old 5th September 2012, 10:20 PM   #317
TonyTecson's Avatar
yes...
i am not familiar with ferite core traffos so i am not able to comment...
Old 6th September 2012, 12:58 AM   #318
totski is offline totski  Philippines
sir tony,i read your thread and interest me very much but for now im not ready to diy a transformer can u send me your email add? here is mine, cerdenia.luisito at yahoo dot com thank's, more power.
Last edited by TonyTecson; 6th September 2012 at 01:55 AM. Reason: email address edited to prevent spamming
Old 6th September 2012, 04:34 PM   #319
wattaniya is offline wattaniya
hi istpyro and tony,
this is how i wind with the drill machine.
Old 6th September 2012, 06:25 PM   #320
looks nice , do u have turn counter too ?
Tony's latest traffo DIY buildHide this!Advertise here!
tony's 6LU8 push-pull power amp build TonyTecson Tubes / Valves 29 8th June 2017 11:12 PM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 07:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 12:34 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 0 27th December 2010 10:59 PM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 11:50 AM
Copyright ©1999-2017 diyAudio
