Tony's latest traffo DIY build
Old 19th August 2012, 03:03 AM   #251
ChrisA is offline ChrisA  United States
Originally Posted by Tony View Post
have you seen the book posted at YvesM's website, is it different from yours? http://www.dissident-audio.com/Trans...ign_Manual.pdf
Your link did not work but i was able to find the book I have on that site. The link below is the same book I have. Except I OCR'd my copy to make it searchable. This book is good and it answers most of the questions that come up in these forums. The other one to get a "Radiotron" 4th ed. on Pete Millet's web site. The section on transformers is good.
Old 19th August 2012, 08:26 AM   #252
Junie is offline Junie  Philippines
Default Winding my own trafo
Hi to all.
Buying a new trafo is expensive, since i have two stepdown(220->110) I'm planning to build my own with the below spec:
Input: 220V/50Hz
Output: 45VAC centertap
18VAC centertap
VA: as per the label it's 1000VA
Now with your help please let me know the following:
  • Primary winding(turns)
  • Secondary windings(turns)
  • Primary wire gauge
  • Secondary wire gauge
I really appreciate for any help you can extend. many thanks in advance.
Old 19th August 2012, 09:30 AM   #253
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
how thick is your stack? even though you have traffo rated 1000voltamps it doesn't mean you will get the same rating....more so if that traffo was auto-transformer type...induction type traffos will be bigger for the same spec....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 19th August 2012, 10:05 AM   #254
Sir Tony it's 0.5mm, I'm planning to use the trafo for Leach amp with 10 O/P tranny. Thanks.
Old 19th August 2012, 10:19 AM   #255
How thick is your stack?
That is the measurement between the bell ends on your pic.
It looks like ~~50mm
2000VA auto transformer could be as little as 200VA and for a 220:110 about 1000VA
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 19th August 2012, 10:28 AM   #256
AndrewT(not going to use Andy at all, sorry for that) i have two trafo:
  • 1500VA-Stack size: 51mm
  • 2000VA-Stack size: 60mm
E core thickness: 0.5mm
Old 19th August 2012, 10:58 AM   #257
42 * 51mm = 2142mm˛ = 3.32sq in of core area.
VA ~ 31 * Core area˛ ~ 31 *3.32*3.32 ~ 340VA for the smaller stack and ~ [60/51]˛ higher for the bigger stack i.e. ~ 470VA.
Certainly not 1000VA.
If you added the two stacks together (not ideal because the stack shape is 42*111= very non square) you could get ~~ 1.6kVA. But there would be relatively small window area for sufficient copper to keep the resistances low.
87mm stack gives ~1kVA
regards Andrew T.
Old 19th August 2012, 11:36 AM   #258
AndrewT if it will yeild me to higher VA I will combine the two trafo as it has the same Size EI core.
Old 19th August 2012, 12:00 PM   #259
Tony, if willing, can give you good and accurate build advice.
Do you really need 1000VA for your intended duty?
regards Andrew T.
Old 19th August 2012, 12:06 PM   #260
Well for Leach Amp with 10 OP is 1000VA too much? I mean in Stereo.
Will wait for Sir Tony's reply then.
Tony's latest traffo DIY buildHide this!Advertise here!
tony's 6LU8 push-pull power amp build TonyTecson Tubes / Valves 29 8th June 2017 11:12 PM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 07:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 12:34 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 0 27th December 2010 10:59 PM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 11:50 AM
Copyright ©1999-2017 diyAudio
