Tony's latest traffo DIY build
Old 23rd November 2017, 08:27 AM   #991
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Originally Posted by saminnografix View Post
i have done it without rewinder of yours sir. i cannot explain my experience sir, made me smile when i imagine myself using even my feet. i was a 1:1 winding by hand.
keep it up,.... you will learn more as you go along...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 23rd November 2017, 10:34 AM   #992
kees52 is offline kees52  Netherlands
I do not to want to hyjack but I am busy with a winder who do go make small signal transformers for mine amp design. So I want to show only.
still wait for some parts.
Old 23rd November 2017, 11:06 AM   #993
R.I.P.
Is the winding controller setting the speed of both motors?
regards Andrew T.
Old 23rd November 2017, 08:46 PM   #994
TonyTecson's Avatar
probably controls the traverse width which can be programmed i imagine...
Old 23rd November 2017, 10:08 PM   #995
TonyTecson's Avatar
please post pics of your work here too, thanks...
Old 24th November 2017, 10:58 AM   #996
Yes The winder do use one motor for winding and one for guiding the wire, because I go to wind a signal transformer who is very small and thin wire I go use this, busy now with biulding it, maybe it is even usable with bigger stepper for winding to make output trafo,s.
I use a core special for signal transformers, it get to 5 Henry multilayer, this can only with that winder, the program and electronics I do not now yet if it works oke, there are also versions on usb and pc.
with the guid motor I can use very thin wire, pause it etc.
Old 24th November 2017, 11:09 AM   #997
pieter t is offline pieter t  Netherlands
I use a core special for signal transformers, it get to 5 Henry multilayer....
Kees, be sure that you wind for much more than 5 Henry.
I guess your reference is 600 ohm (divided by 2pi.F), but this way the transformer will have very little input signal capacity (saturation); go for something like 150H to present a ~ 20k AC load; that's doable on your core with thin wire.
(Sorry Tony to break in a little here....)
Old 24th November 2017, 11:16 AM   #998
If I do not hijack I do post the pictures when progress.
Old 24th November 2017, 12:23 PM   #999
I have look here and see that 5 Henry is used there in a manufactored one, I do now output transformers for tube has high inductance like you mention, I think 150 H do not fit on that transformer.
Transformers for Audio
I think to start a new thread because we hijack Tony.
Old 31st January 2018, 02:10 AM   #1000
TonyTecson's Avatar
that is fine kees52, you are welcome to post here...
Tony's latest traffo DIY buildHide this!Advertise here!
tony's 6LU8 push-pull power amp build TonyTecson Tubes / Valves 31 7th April 2018 02:56 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 2 4th October 2017 01:03 AM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 07:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 12:34 AM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 11:50 AM
