Tony's latest traffo DIY build - Page 77 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th October 2016, 10:46 AM   #761
Originally Posted by AndrewT View Post
Load both windings to deliver 2.4Aac + 2.4Aac into 9r17 + 9r17 and check how hot it gets after 30minutes.
22Vac+22Vac @ 2.4Aac+2.4Aac is equivalent to an output rating of 105.6VA
Thanks Andrew. How many watts would I need for those resistors?
Old 10th October 2016, 10:50 AM   #762
AJT is offline AJT  Philippines
AJT's Avatar
transformer heating is different with a resistor load, than with a rectifier....
no need to go there.....
listening to music, you will not be consuming more than 30 watts or else
you ears may hurt due to the loud sound coming from your speakers....
the best advertisement for a good audio design is the number of diy'ers wanting to build it after all the years....never the say so of so called gurus....
Old 10th October 2016, 10:53 AM   #763
I guess that's enough questions for today
Thanks for your responses.
Old 10th October 2016, 10:54 AM   #764
AJT's Avatar
there is no reason to overthink your traffo, the fact that you were able to rewind your toroid is proof enough for me that you know what you are doing.....
so my advice to you is, just go ahead and do it....
Old 10th October 2016, 10:57 AM   #765
Each will be taking ~53W so they will get very hot. Try 100W with good ventilation.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 11th October 2016, 12:08 AM   #766
AJT's Avatar
Tony's Line conditioner finished.....230V primary to 230 volt secondary
rated for 1500VA, has a low power winding good for about 200 watts
to use on low power such as test equipment....
Old 5th January 2017, 11:35 PM   #767
AJT's Avatar
new traffo for a second 6C33 OTL amp build......
1 3/4 inch center leg, stacked to 4 inches, and weighs in at 12kgs..
winding electrostatic shields...
sun drying after soaking in electrical varnish...
finished traffo...
Old 10th January 2017, 01:36 AM   #768
to all masters
i want to build a traffo for my APEX500 since i cannot find traffo in our area that has correct va rating, since commercial traffo indicates false VA (in our area).
first Q - will 55-0-55 be enough for b500? how many amperes?
all i have found in the market was EI core with CL 1 1/2" and CL-3"
i bought about 1.5"x5" inches coz 3"CL has the height of 6.75"more or less and the price is 300% higher.
may i ask the specs for the primary and secondary windings?
vis-a-vis t/v and primary and secondary turns.
thank
regards...
Old 19th January 2017, 06:51 AM   #769
AJT's Avatar
1.5"x5" inches will give you about 1500 volt amperes
so that 2 x 55 windings will give you 8 amperes....
still good for your intended project....
this as far as i go....
you have to study on your own about the winding details,
enough information are available on the net.....
Old 19th January 2017, 07:04 AM   #770
Thanks sir Tony,
regards
tony's 6LU8 push-pull power amp build AJT Tubes / Valves 28 6th September 2015 02:07 AM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 08:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 01:34 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 0 27th December 2010 11:59 PM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 12:50 PM
Copyright 1999-2017 diyAudio
