Tony's latest traffo DIY build - Page 54 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th August 2013, 11:24 AM   #531
sorry i forgot uploading pics
Old 7th August 2013, 11:27 AM   #532
1 more
Old 7th August 2013, 12:19 PM   #533
TonyTecson's Avatar
looks like you have a 1kva torroid there...
you can use this data....Toroidal Core PN# 140 | PN# 140
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 7th August 2013, 12:51 PM   #534
it was from phonic amplifier
Old 8th August 2013, 06:01 AM   #535
TonyTecson's Avatar
if you click the link you will see this....
Epoxy Coated Toroid, Id=3.500", Od=6.125", Ht=2.125", 2683 VA Relative Power Handling, 0.684 V/turn @60Hz, 15KG
Option: 117V 60Hz Primary, 166 turns of AWG#12 155 C magnet wire. 6" self-lead wire Includes taped primary.
so in India, that will be 332 turns #16 wires,
turns per volt = 1.42
you can use #14 wires for secondaries...
Old 8th September 2013, 04:22 PM   #536
alvin p is offline alvin p  Philippines
Sir Tony, could you help me with this transformer that I want to build? I have 1 3/4" deeco core stacked to 3 inches. I am planning to build a 220V primary with 50-0-50 secondary. Could you help me with the turns and size of the wires considering the maximum secondary current that could fit in this core? I would like to maximize the current capacity for the 50-0-50 secondary. Thank you very much.
Old 13th September 2013, 06:07 PM   #537
Banned
can 220v > 185v 400miliamphere be winded on aa 57mm EI lamination?
Old 13th September 2013, 11:44 PM   #538
TonyTecson's Avatar
what is stack height? looks like a too smalll...
Old 13th September 2013, 11:48 PM   #539
TonyTecson's Avatar
1.45 turns per volt..
#19 primary
#15 secondary
bobbins are available for this size of coil
Old 16th September 2013, 12:42 PM   #540
Thank you sir Tony. I already have a bobbin for this.
tony's 6LU8 push-pull power amp build TonyTecson Tubes / Valves 28 6th September 2015 01:07 AM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 07:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 12:34 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 0 27th December 2010 10:59 PM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 11:50 AM
Copyright 1999-2017 diyAudio
