Tony's latest traffo DIY build - Page 35 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th December 2012, 10:15 AM   #341
Tony,
I think I know what you are doing, But could you explain so that I and anyone else fully understands the tests you are applying?
Why does the spreadsheet have xlsx? What does that last x mean?
Please explain the plots and how to read the information in them.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 14th December 2012, 10:06 PM   #342
AJT is offline AJT  Philippines
AJT's Avatar
i am using Office 2007 for the spreadsheet......i attached revised spreadsheet showing efficiencies at various primary currents...the short circuit testing is done with all secondaries shorted together, with the aid of a variac, the voltage is slowly increased until a specified current flows as registered in the ammeters, the voltage at which the specified current flows is basis for computing copper loss in watts, that is v x i........
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 15th December 2012, 09:54 AM   #343
Once again, could you explain how to use or read this information?
regards Andrew T.
Old 15th December 2012, 10:41 AM   #344
AJT's Avatar
i am building my database so i can compare losses between types of cores, soon i will be making the same dimensions and coils but will use higher grade type irons......
the core loss and copper losses can then be compared with a comparable traffo using better grade iron core materials...
the spreadsheet is self explanatory....
Old 22nd December 2012, 02:12 AM   #345
AJT's Avatar
Default a pair of 6C33 push-pull OPT's
just finished, took me 2 days from get go....
Old 22nd December 2012, 02:19 AM   #346
AJT's Avatar
more pics...
Old 1st January 2013, 03:19 PM   #347
noSmoking's Avatar
Hi Tony,
Those look Pro,lol Good job !
I haven't wound my first one yet but am thinking about buying some wire and getting started,lol.
NS
Old 1st January 2013, 11:04 PM   #348
AJT's Avatar
Originally Posted by noSmoking View Post
Hi Tony,
NS
yes, that is the reason i post, to get you out to doing your own OPT's....
Old 2nd January 2013, 12:26 AM   #349
prairieboy's Avatar
I'm envious ...
Old 2nd January 2013, 09:55 AM   #350
Cool Tony... those traffos popping out like daisy's...
you are responsible for shortage of 2" core and copper at deeco
Will be joining the party shortly as I have 4 pcs 200Watts output booster traffo EI core. Will be taking photos and exact measure of IE iron core in the next few days...
Pinoy ikaw ay pinoy... ipakita sa mundo... kung ano ang kaya mo...
tony's 6LU8 push-pull power amp build AJT Tubes / Valves 28 6th September 2015 01:07 AM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 07:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 12:34 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 0 27th December 2010 10:59 PM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 11:50 AM
Copyright 1999-2017 diyAudio
