Tony's latest traffo DIY build - Page 33 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th September 2012, 04:36 AM   #321
Originally Posted by Aucosticraft View Post
looks nice , do u have turn counter too ?
thanks,
i dont have turn counter,
after i wind and checking turns . this wires are thick, so counting turns not hard, but small wires problem counting turns.
Old 10th September 2012, 07:04 AM   #322
hi tony,
is this bolt and nuts perfect for lamination tightening?
it is galvanized bolt and nuts. 4 inch long.
Old 10th September 2012, 07:49 AM   #323
TonyTecson's Avatar
Originally Posted by nazirdigi View Post
hi tony,
yes, that will do.....look for shoulder washers to use with your bolts and nuts, better to use them for cooler running traffo...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 10th September 2012, 02:27 PM   #324
thanks tony for the reply.
Old 18th September 2012, 01:52 PM   #325
hi tony,
i am busy these days, because last days i am in my wife place,
i am facing a big problem with wire gauges, i didn't ask wire size in mm, when i buy magnet wires, i asked in gauges, today i bought a micro mm measurement tool and measured the gauge no-15 it shows 1.80mm, i checked the supplier chart and it shows 1.80mm, in ur chart, shows 1.45mm,
i already told u gauge no-13 hard to wind, i checked that one also, micro mm measurement tool shows 2.25mm , in ur chart showing 1.90mm.
i already wind secondary 42turns into 4 with 1.80mm gauge wire, i didnt wind primary yet,
so can u help me to solve this problem.
Old 18th September 2012, 03:15 PM   #326
hi tony,
lamination thick is .5mm.
i remove the enamel and measure the wires.
Old 18th September 2012, 11:40 PM   #327
TonyTecson's Avatar
hi tony,
i already wind secondary 42turns into 4 with 1.80mm gauge wire, i didnt wind primary yet, so can u help me to solve this problem.
that is because in India the British standard applies, while in Manila we use the American standard.....
so better get wires based on my table on diameter in mm....
Old 19th September 2012, 05:34 AM   #328
hi tony,
why this no-13 gauge different from both images. only no-13 is different.
in post no-199 u mention no-13gauge for secondary , is it 1.83mm or 1.90mm?
because in the images two charts showing two values,
so no-1.83mm is ok, can i use 1.80mm gauge, because in here 1.83mm is not available.
Old 19th September 2012, 05:55 AM   #329
TonyTecson's Avatar
just follow the nearest mm diameter....
Old 19th September 2012, 06:12 AM   #330
thanks tony.
but u didn't tell the gauge (no-13) 1.83mm or 1.90mm.
i searched the datasheets for awg on the web the no13 showing 1.83mm.
tony's 6LU8 push-pull power amp build TonyTecson Tubes / Valves 28 6th September 2015 01:07 AM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 07:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 12:34 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 0 27th December 2010 10:59 PM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 11:50 AM
Copyright 1999-2017 diyAudio
