#21 |
sir tony anu po ginamit nyo na electrostic shield na gamit nu???
#22 |
damn that is nice trafo, nice finish!
#23 | |
i used copper sheet for electrostatic shielding, in other traffos i have dismantled, single layer copper coils were used......
http://www.elab.ph/forum/index.php?topic=32688.0 Last edited by Tony; 16th August 2011 at 08:59 AM. |
#24 |
thanks Luka, i must grive credit to YvesM, i first saw him did this although on smaller traffos.....this one has a 2inch center leg, so i guess this is pretty much justified....
http://www.elab.ph/forum/index.php?topic=32688.0 |
#25 |
thank sir tony. maybe the mod wont mind it. some are speaking there home language once in a while. you think could i use aluminum foil used in wrapping food?
#26 |
yes, i used aluminum duct tapes on some occasions......just make sure you don't create shorted turns.....
#27 |
sir what is the largest EI core can i find at deeco.?
do they have a 3 inch tounged E core?
i love electronics.......but electronics hate me....... |
#28 | |
last time i was there they had 40kgs of 2 1/2 inch cores..... the largest core i've used is a 2 1/4 inch core....
#29 |
^i was at Raon/Evangelista this morning.......i was told by Marlon that he has 50kg stock of 3inch center leg cores....they are located opposite the Bearing center in Evangelista street.
#30 |
i have bobbins for 1 3/4 and 1 1/2 inch cores, so to facilitate winding, i made some wooden mandrels...
| tony's 6LU8 push-pull power amp build | Tony | Tubes / Valves | 22 | 23rd February 2013 06:21 AM |
| Trinium, my latest build | Mark.Clappers | Multi-Way | 18 | 17th July 2012 07:07 PM |
| My latest CHR-70 build | tresch | Full Range | 8 | 6th December 2011 12:34 AM |
| My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 | LinuksGuru | Tubes / Valves | 0 | 27th December 2010 10:59 PM |
| My latest build SS 23W | smithy666 | Subwoofers | 6 | 14th April 2009 11:50 AM |
