Tony's latest traffo DIY build - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 1st July 2011, 12:27 AM   #11
TonyTecson's Avatar
some more:
GeeK ZonE - Winding Your Own Transformers
Transformer
DIY Output Transformer
Build your own transformers • DIY Audio Projects Forum
Re: Building your own HV transformer
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 5th July 2011, 02:46 AM   #12
TonyTecson's Avatar
aikido preamp transformer diy:
Old 5th July 2011, 10:44 AM   #13
I get the impression it is quite big !
Give details of size, weight, VA, Vac, windings, turns or turns ratios, etc.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 6th July 2011, 02:54 AM   #14
TonyTecson's Avatar
Big? not really, core is a 1 1/4inch squared, core rating of about 75VA,
primary at 220volts,60hz, 950 turns of #24 magnet wire, layer wound.
secondary1 at 120volts, 0.4 amps, 570 turns of #27 magnet wire, layer wound
secondary2&3 at 6.3volts center tapped, 3.0amps, 28turns of #18 magnet wire..
Old 15th August 2011, 10:50 AM   #15
TonyTecson's Avatar
update:
after painting the traffo, i had some aluminum covers made, since no end bells can be found anywhere for 2inch cores that i know of:
Old 16th August 2011, 01:34 AM   #16
Junm is offline Junm  Philippines
Junm's Avatar
Send a message via Yahoo to Junm
wow...nice build sir....it's really nice building your own trafo especially if u have those equipments....customizing trafo for you own use is really a factor and sometimes cost saving rather than buying ready made trafo that not exactly as u want...some store sell trafo of false VA rating just voltage and amperage and you dont know wether it for a single wind rating or dual...if you not familiar with the core size you can be fooled.
Old 16th August 2011, 02:42 AM   #17
TonyTecson's Avatar
thanks, one reason i build my own traffos is so that i get what i want and not be limited in that sense.....
Old 16th August 2011, 03:18 AM   #18
Junm's Avatar
Sir,do you accept special orders?
Old 16th August 2011, 04:11 AM   #19
TonyTecson's Avatar
not really, still a hobby for me, but fire me an email with your requiements and i may be able to help.....
Old 16th August 2011, 05:05 AM   #20
Junm's Avatar
okay sir..when i finish my ongoing projects i will give you a call.... btw, do you have pcb's for leach amp available for sale? i'm planning to assemble one.
tony's 6LU8 push-pull power amp build TonyTecson Tubes / Valves 28 6th September 2015 01:07 AM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 07:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 12:34 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 0 27th December 2010 10:59 PM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 11:50 AM
Copyright 1999-2017 diyAudio
