Tony's latest traffo DIY build - Page 11 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th November 2011, 07:16 PM   #101
hi tony,
is this softwares perfect?
what is cross section in awg table?
Old 10th November 2011, 07:50 PM   #102
the left pic must be wrong.
Those X & Y dimensions must be about a factor of 10 in error.
Could it be he has his mm and cm mixed up?
The middle pic seems to be right I have used it to estimate EI transformers I have bought secondhand or inside existing equipment. One part missing from Klaic' software is choosing the working flux.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 10th November 2011, 10:01 PM   #103
AJT is offline AJT  Philippines
AJT's Avatar
Originally Posted by nazirdigi View Post
hi tony,
the picture on the left must be in cm not mm as shown, otherwise the calculations are okay.......
cross-section area = (2pi x diam)/4 = (6.28 x diam.)/4, it forms basis for current density in your copper, i am used to imperial units, i use 500 or 700 cm per ampere current density. the ARRL handbook has this nice table to look at...
Do not despair, though they seem to be winning
now, they always fall in the end......Gandhi
Old 11th November 2011, 01:15 AM   #104
thanks andrew and tony for replies,
do u have any other softwares for calculations.
thanks.
Old 11th November 2011, 03:02 AM   #105
AJT's Avatar
i do not have other software's, to be frank about it, i do not use those calculators as a basis for my designs but for preliminary computations at times......
as you go along making transformers, designing and building becomes as easy as counting 1 2 3.........
Old 15th November 2011, 07:58 AM   #106
sir Tony, I have this CRGO core, and size u can see,
can u tell me about winding to get 80-40-0-40-80volts at25 amp?
Thank u
Old 15th November 2011, 09:22 AM   #107
AJT's Avatar
Thank u
have you done traffo winding before?
Old 15th November 2011, 11:49 AM   #108
yes, since2000,
i know how to wind, i saw this,
Old 15th November 2011, 11:59 AM   #109
And i also have Transfomer winding calculation softwar which shown by Sir nazirdigi
Old 15th November 2011, 12:06 PM   #110
San,
using the 40+40Vac windings as the 25Aac you require 2kVA from the transformer.
The 2" core stacked to 3" thick gives 6sq" of core area.
That equates to ~1100VA. Well short of 25Aac @ 40+40Vac.
12Aac for the 40Vac windings and 7Aac for the extra 40Vac windings would seem to be in the ball park.
I think that is why Tony asked
regards Andrew T.
tony's 6LU8 push-pull power amp build AJT Tubes / Valves 28 6th September 2015 02:07 AM
Trinium, my latest build Mark.Clappers Multi-Way 18 17th July 2012 08:07 PM
My latest CHR-70 build tresch Full Range 8 6th December 2011 01:34 AM
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 0 27th December 2010 11:59 PM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 12:50 PM
Copyright 1999-2017 diyAudio
