Go Back   Home > Forums > Amplifiers > Power Supplies
Old 22nd December 2011, 12:27 PM   #161
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
thanks, just ask here if you have other concerns and we'll see what we can do....
Old 28th December 2011, 02:48 PM   #162
yeah, i like that... sir tony can you give me the right computation of toroidal 70 volts and 12 volts? in the EI Core transformer here is my computation.
Here is the Computation of EI core Transformer Philippines Base
Old 28th December 2011, 10:16 PM   #163
Tony's Avatar
^you need to give me the dimensions of your torroid core, inside diameter, outside diameter, height......
torroid cores operate with higher T's.....more than EI's....
Old 30th December 2011, 12:46 AM   #164
Tony's Avatar
Default [b]blue, blue, my traffos are in blue:[/b]
8k a-a primaries to 4/8/16ohm secondaries:
with power traffo:
4k a-a primaries to 4/8/16ohm secondaries:
with power traffo:
two sets of irons for two amplifiers:
Old 30th December 2011, 06:14 AM   #165
lovely - very well done - those end bells look fantastic. was wondering today how hard it would be to press them from sheet steel if you had a mandrel made ect and used a 12T press. definately going to have a go at this - i found the winding tool on fleabay also so I will order one from hong kong and give it a try. we can (locally here in AU) get the E I and bobbins / copper wire no problems.
Old 14th January 2012, 04:54 AM   #166
TechGuy is offline TechGuy  United States
Grega,
50/60 hz Laminated Transformers use Silicon steel instead of ordinary steel to reduce core losses.
Electrical steel - Wikipedia, the free encyclopedia
Old 14th January 2012, 09:25 AM   #167
Do you think that the sellers/manufacturers of the cheaper offerings bother to read Wikipedia
regards Andrew T.
Old 29th January 2012, 08:41 AM   #168
Tony's Avatar
traffo for a 12AX7 tube preamp.....
2 traffos, one for plate B+, 280volts at 50mA, the other one for filament supply, 12-0-12volts at 0.8A
installed inside the preamp chassis:
Old 12th February 2012, 10:41 PM   #169
Tony's Avatar
to break the boredom i decided to make a current transformer, ratio is 1:1000 so that an ampere on the primary causes 1mA to flow thr the seconday.....
secondary coil uses 1000turns #33 wire on a 5/8 bobbin:
secondary leads ready for termination...
primary coil is a single turn of an insulated flat copper foil(from an atx psu traffo), pigtails soldered at both ends...
cores are installed next:
brackets installed:
i am going to use this ct to make a 0-10A analog meter using a dc 0-10mA panel meter.
Old 14th March 2012, 02:16 AM   #170
Tony's Avatar
finished 2 power traffo's last night:
i used bamboo pegs on 4 holes of the traffo, slightly tight fit, so they don't fall off......
dipping in a pool of varnish, traffo is completely submerged, wait until bubbles disappear, do this several times:
draining off excess varnish, again bamboo barbecue sticks are useful here:
when dripping stops, traffos are hung out to dry, this takes 2 to 3 days:
My Latest DIY Draft (Beta) Build - Resurrected Sansui AU-111 LinuksGuru Tubes / Valves 0 27th December 2010 10:59 PM
Earthing concern - pre amp and traffo help AndrewGM Solid State 19 9th January 2010 11:56 PM
Funny traffo specs Atilla Power Supplies 6 18th September 2009 08:28 AM
My latest build SS 23W smithy666 Subwoofers 6 14th April 2009 11:50 AM
Traffo connection QS Bassivus Power Supplies 3 22nd October 2006 11:33 AM
Page generated in 0.08543 seconds (84.00% PHP - 16.00% MySQL) with 11 queries
