Simple dual PS - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th June 2011, 06:11 PM   #11
Banned
Mooly, I don't thinks he's picked up on the active grounds. The simple resistive virtual ground isn't really suited to high power use, not without using huge resistors and wasting an enormous amount of power.
Old 29th June 2011, 06:22 PM   #12
Mooly's Avatar
Could be...
Installing and using LTspice IV. From beginner to advanced.
Old 29th June 2011, 06:48 PM   #13
dgta is offline dgta  United States
I did pick up on the active ground. Even if I expect a small-ish load imbalance, I would need at least a rail splitter like the TLE2426, which doesn't handle 80V, or a plain opamp DIY rail splitter, and I still need a high voltage opamp. And this is still a small ground current setup, unless I add a pass transistor.
With your (Andy's) circuit, the opamps don't pass any load current, ground or otherwise, so I can use just one rail of the supply for single-sided circuits, if needed, up to full regulator capability. All this for the price of 2 opamps instead of 1 plus a transistor and associated circuitry. Seems like a winner to me.
Aleph 5 single PS or dual? Leeuwarden Pass Labs 24 8th December 2014 01:48 PM
Dual caps for S.S. PS filtering cdfac Power Supplies 0 9th March 2010 02:17 PM
Help with dual PS noise shunt? cuibono Power Supplies 15 22nd March 2008 09:00 PM
Pseudo dual mono PS? Sherman Tubes / Valves 2 22nd September 2006 11:38 PM
Dual Transformers for a PS? amo Chip Amps 13 20th February 2004 07:30 PM
Copyright 1999-2017 diyAudio
