Go Back   Home > Forums > Amplifiers > Power Supplies
Old 27th June 2011, 07:43 PM   #11
SY's Avatar
Mouser. Never got a fake from them.
If there's a sucker born every minute, where do the rest of them come from?
Old 28th June 2011, 01:24 AM   #12
Noted the CCS using Mosfet in HMN phono pre
For now, just would like to know how to implement using a resistor
Old 28th June 2011, 02:00 AM   #13
SY's Avatar
That depends. What circuit are you putting it in?
If you know the voltage across the CCS, you can calculate a resistor from R = V/I.
Old 28th June 2011, 10:19 AM   #14
CCS is to feed a shunt regulator for a preamp supply
So just measure the voltage across input and VR output.
Remove everthing that is shown in my schematic, Right?
Old 28th June 2011, 12:37 PM   #15
SY's Avatar
Pretty much, yes. Presumably, the CCS was sized to be twice the maximum expected current. If the raw supply has any sag under load, take that into account in the Ohm's Law calculation.
Old 29th June 2011, 02:49 AM   #16
Thank you SY for your explanation. Is that simple, hopefully it will sound better than
LM317T CCS
Old 1st July 2011, 04:16 AM   #17
If I remove the whole ccs circuit including mosfet, zener, resisors, etc and replace with a resistor, would not the circuit becomes ordinally current flow and not constant current flow? Just like a plate resistor.
Or I just replace only the LM317 after measuring the voltage across it
This tweak was discussed in Audio Asylum for the Super Regulator sold by Vacuum State,
but the exact method was given through PM
Glad to know how exactly it is done
Old 1st July 2011, 08:50 AM   #18
Schematics
Old 1st July 2011, 09:54 AM   #19
SY's Avatar
Yes. You lose most of the benefit of the CCS by doing this. I'm still not sure of the motivation, but I suspect Allen Wright is spinning in his grave.
Help!! LM317T Filament Heater Problem ron944 Analog Line Level 2 17th December 2010 09:03 PM
Is a LM335 a direct replacement for a LM317T? phrarod Tubes / Valves 13 18th April 2010 01:30 AM
Oscons and LM317t Htguy Swap Meet 15 4th April 2006 04:14 PM
LM317T regulate current and voltage? Nordic Power Supplies 7 5th March 2006 07:18 PM
Copyright ©1999-2013 diyAudio
