Go Back   Home > Forums > Amplifiers > Power Supplies
Old 27th June 2011, 07:18 AM   #31
karmik is offline karmik  Italy
karmik's Avatar
Send a message via ICQ to karmik Send a message via AIM to karmik Send a message via MSN to karmik Send a message via Yahoo to karmik
Well you gave me a very nice news sir The dc/dc converter is not cheap (7 euros for one) but overall i believe it will be a cheaper solution.
42 milliamperes on each rail should be enough to drive an OPA2134 right?
Old 27th June 2011, 04:46 PM   #32
Mooly's Avatar
It will run several OPA2134 (10ma per package worst case) so no problems there.
A simulation free zone. Design it, build it, test it.
Old 27th June 2011, 05:52 PM   #33
Banned
Originally Posted by karmik View Post
That's what i thought!
Ok so, i worked a bit on the schematic and i think much of the incomprehension came from my poor skills rather than actual problems, i apologize for that.
To draw this schematic i copied information from:
So here is it, what did i get wrong this time?
Thanks for your feedback!
Just don't connect Virtual 0V to 0V because they are different DC potentials.
Old 27th June 2011, 06:18 PM   #34
Mooly's Avatar
Its not that easy as both are used as reference points for the audio... they have to be connected. Can't think of an easy way to explain it
Old 27th June 2011, 10:46 PM   #35
As said before, it will work if you AC couple the pre-amp and power amp.
(Just fix the small error: R1/R2 junction should tie to the +IN, not -IN, of the opmps).
But if your brick can do +12V, the DC-DC convertor solution of Mooly is much more elegant.
Old 27th June 2011, 11:11 PM   #36
Minion is offline Minion  Canada
If you can get a 12v AC transformer you can use a Voltage doubler and regulators to get your +/- 12v DC then use a seperate rectifier and regulator for your 12v DC for the power amp ......
The Preamp won"t use very much current so a voltage doubler would be suitable and there isn"t a problem with it sucking more from one rail .....
Cheers
Old 28th June 2011, 08:25 AM   #37
karmik's Avatar
I'll fix the schematic as soon as possible, but i think i'll go with Mooly's solution. Would it be a good idea to regulate the 2 rails after the dc/dc converter as well? or would that be overkill?
Best regards,
GC
Old 28th June 2011, 10:27 AM   #38
Mooly's Avatar
Best regards,
GC
You have many options... you could go with a 15/0/15 convertor and use 78and 79L12 regs. The 3 volts is sufficient headroom for these to work well.
You could just use a simple R/C filter feeding the opamp rails.
Or just use it "as is" with suitable caps on each rail.
Or again with a 15 volt reg you could use a resistor/zener/cap arrangement which in many cases for low currents is a very good option... this "shunt" arrangement is the one I use in my integrated amp.
single-ended power supply (12V) based active crossover r_s_dhar Car Audio 8 15th April 2011 08:44 PM
+/- 12v regulated power supply review needed renfrow Power Supplies 6 26th October 2008 10:35 AM
Searching for a quality amp for single 12V supply Otherwise Chip Amps 9 4th September 2006 11:54 PM
12V-220V(ac) to 12V-50V(dc) raszvan Car Audio 0 16th June 2005 08:28 AM
12V Power Supply Needed for a on-board Car Computer ap0the0sis Parts 15 6th April 2004 12:55 AM
Copyright ©1999-2013 diyAudio
