Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th June 2011, 04:43 PM   #1
dazed is offline dazed  Norway
Default PSU's for Squeezebox and USB D/A converter?
I have a Squeezebox Touch and two Abrahamsen A-dac usb D/A converters that I'd like to build decent power supplies for. Just as an experiment, to see if they'll sound better. (...And just because it's fun, of course.)
The D/A Converters have 24V DC 0.5A wall warts, and the Squeezebox has a 5V DC 3A wall wart.
I'm looking for PCB's or preferably complete kits for good power supplies to replace these. I need transformers with primary windings for 230VAC european power grids (in Norway).
The best would be kits that I could use for both these applications. (With different transformers, of course).
I've built a couple of TREAD and STEPS supplies on PCBs from Tangentsoft, but sadly these are no longer available. Neither are his newer YJPS pcb.
Where should I look?
All tips and pointers will be greatly appreciated.
Thanks!
Old 25th June 2011, 09:09 PM   #2
I ordered three σ11 boards and the parts AMB has for it in his webshop. Looks good for this application, I think.
Now to figure out what transformers, enclosures and other small parts I need.
Old 26th June 2011, 12:47 PM   #3
You kan make a simpel, by your self
Old 26th June 2011, 01:14 PM   #4
mravlca is offline mravlca  Slovenia
mravlca's Avatar
Default Squeezebox PSU
I've made this PCB for Squeezebox linear PSU. The PCB can accept also TO-220 devices such as LT1085 or similar.
Best Regards,
Ales
Old 27th June 2011, 08:54 AM   #5
Thanks! I'll just try the σ11's now that I ordered the boards, I guess.
Did you notice any difference in eprformance from your squeezebox with the new psu?
Old 28th June 2011, 08:25 AM   #6
mravlca's Avatar
Yes! On my sistem the biggest improvment was on soundstage! I think you should get even better results with σ11.
BR,
Ales
Old 28th June 2011, 10:04 AM   #7
Thanks. That sounds promising.
USB to SPDIF Converter mp006ltk Digital Source 13 15th September 2011 04:03 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
USB to SPDIF converter rokoko Digital Line Level 12 8th July 2009 07:19 PM
Another USB to SPDIF converter Kane Williams Digital Line Level 0 10th October 2008 10:25 PM
Page generated in 0.08696 seconds (73.66% PHP - 26.34% MySQL) with 11 queries
