Problem with using UC3855: Low output Voltage
Old 23rd June 2011, 11:54 AM   #1
Papajo is offline Papajo
Default Problem with using UC3855: Low output Voltage
Hello everybody...
I am trying to use UC3855 (or UC2855) from TI, but i have a problem with output voltage. Some informations:
Vin 85-270Vac
Vout 400Vdc
Pomax 2.5KW
Fs 150KHz
My main inductor is 200uH, ZVT inductor at about 10uH,
STW45NM50 for main MOSFET and STW20NM50 for ZVT MOSFET (both of them are driven with ACPL-H312-000E), STTH6012 for main Diode and DSEI30-10A for the ZVT circuit.
In the tests i am doing now, i use as load 1KW. For whatever input voltage i apply, from 85 to 240V, i haven't seen the output Voltage going above 300V. However, switching of the MOSFETS seems to be correct (using a scope).
I also have problem with the temperature of the ZVT inductor (in just 1 min of working, the temperature of the core goes to almost 100oC).
Has anybody who used UC3855 noticed anything similar in output voltage?
Problem with using UC3855: Low output VoltageHide this!Advertise here!
peavey mkvi bass - low output problem misterfixit Instruments and Amps 4 6th October 2014 08:05 AM
High voltage, low current output stage for class D amplifier ionomolo Class D 45 15th February 2011 06:03 PM
Problem with Aragon 24k - pop and low output Richter17 Solid State 0 25th December 2009 02:26 AM
Problem with Lm3886 output voltage JohnnyP00 Chip Amps 12 7th March 2009 10:36 PM
eqt with low output voltage marko Car Audio 6 2nd January 2007 12:19 AM
Copyright ©1999-2017 diyAudio
