I have a ~170va IE core transformer. At no load it is drawing .220a. After leaving it connected for an hour it is 105 Deg F, so it is warm but not hot. It is a split bobbin and I have unwound the secondary with plans to rewind it for the voltage I need.
Checking the current waveform, I see peaks, as if it is saturating. Not sure why this would be happening. (?) |
#2 |
0.22 A * 120 V = 26 VA. That's way too much loss. I bet it is saturating as you say.
~Tom |
| Where you buy iron transformer core for DIY audio transformer | tarsik | Tubes / Valves | 10 | 27th December 2011 08:15 PM |
| Dynaco 440 Transformer Cathode/Screen Taps 6P1P 6AQ5 UL transformer | TheGimp | Tubes / Valves | 14 | 30th October 2011 12:20 AM |
| Using a large 60hz toroid transformer as an SMPS transformer | EWorkshop1708 | Power Supplies | 20 | 22nd June 2011 08:05 PM |
| TV Fly-Back Transformer as and Audio Transformer Anyone :) | AB5NI | Everything Else | 7 | 10th June 2011 11:22 PM |
| toroid Transformer as output Transformer for tube preamp? | tone | Tubes / Valves | 15 | 2nd February 2003 04:36 AM |
| Page generated in 0.06471 seconds (68.24% PHP - 31.76% MySQL) with 10 queries |
