Hi, I just inherited a KRELL KRC preamplifier, a beautiful device but with a flaw: it lacks the power cable connecting the power supply to the device itself, it is a cable with DB9 F sockets .
I am seeking information on how the connectors are soldered , I guess the wiring is not standard, thank you for information ... Jean François de Toulouse France |
#2 |
Just a random thought: Have you asked Krell? I have never dealt with them, but I did ask Parasound for the schematics of their amps and they provided them as .pdf files free of charge. Maybe Krell will tell you the pinout.... You won't know unless you ask.
~Tom |
#3 |
Hopefullly Krell tell you ( or try to sell you a $15.00 cable for $150.00.)
I expect the standard cable with pin 1 to pin 1 , pin 2 to pin 2 will likely be the connection - you could check this by getting the standard cable and removing the covers on both preamp and power amp and NOT POWERING the power supply and just check with an ohm meter that the positive output of the power supply went to the positive of the preamplifier, ground to ground , negative to negative ( if the power supply is dual mono then check for each channel. If that tracing of connnections seems to follow what you measure - only then power it up. |
| Looking for Krell KRC-3 preamp schematics | eboy2003 | Analog Line Level | 0 | 15th January 2011 08:48 PM |
| Krell KRC powersupply | BrianEno | Solid State | 0 | 3rd December 2010 12:32 PM |
| WANTED - KRELL KRC-HR Solid State Preamp | speedemon | Swap Meet | 5 | 21st November 2010 01:43 AM |
| Power Supply Question- Single lead to Caps | lgreen | Solid State | 6 | 26th June 2006 03:19 PM |
| Krell KRC-3 | aarsoe | Solid State | 0 | 1st November 2004 02:57 PM |
| Page generated in 0.06142 seconds (71.69% PHP - 28.31% MySQL) with 10 queries |
