Go Back   Home > Forums > Amplifiers > Power Supplies
Old 21st June 2011, 02:48 PM   #1
imfree707's Avatar
Send a message via Yahoo to imfree707
Default SMP Rails?
Has anyone seen any modular, that is circuit board-only, Switch Mode PSU's with 120-240V input and +/- Rail outputs for operating Audio Power Amps? A line of these PSU's would be great and could cost less than EI or Toroidal Transformers, these days, and be a Chip-Amp DIYer's dream!!!!
A stiff power supply in a great-sounding amp is always better for you than a stiff drink.
Old 25th June 2011, 01:23 AM   #2
! is offline !  United States
You could use two of the same SMPS in series, though at least the PSU delivering the negative rail would need a floating ground (relative to earth and chassis ground) so you hook them up with PSU #1 having positive rail voltage and negative at earth ground potential, and PSU #2 has positive rail at earth ground (wired to the negative on PSU #1) and its *ground* is no longer ground, it's the negative rail.
It depends on the DIYer whether it would be a DIYer's dream, chip amps have much better PSRR with linear PSU than with SMPS, they will be more accurate with linear and sound artificially "lively" with SMPS... which some people like, but some don't.
Another idea come to mind, use an opamp, voltage divider subcircuit and create a virtual ground between the single rail SMPS positive and negative (again your PSU negative has to be a floating ground, not connected to earth ground in most amp designs).
If you could find the dual rail PSU as a ready made product used in lots of devices, then yes the cost "could" (but wouldn't necessarily be) be lower than EI or toroidal linear PSU, but as you've noted when you inquired - that they are rare in capacities a chipamp DIYer would want - the limited availability means fewer produced, driving up development and manufacturing cost.
Benefits/Drawbacks of Dual rails vs Single Rails buzzforb Pass Labs 2 25th May 2011 01:06 PM
Minebea 500W SMP on Ebay 405man Power Supplies 3 21st November 2009 02:34 PM
Samick SMP-4000 tom daghdha Solid State 2 4th April 2009 12:39 AM
Chipamp with SMP pjpoes Chip Amps 10 23rd June 2007 11:20 AM
filament rails resident Tubes / Valves 2 22nd October 2004 12:48 PM
Page generated in 0.06962 seconds (71.21% PHP - 28.79% MySQL) with 10 queries
